Air Bag Code
Old Feb 10, 2007 | 08:42 PM
Hawk180's Avatar
Hawk180
Air Bag Code
I've been getting an intermittent 32 code on my air bag. Has anyone had this before? Does this mean I need to replace the air bag? According to the manual, it means a high resistance reading over the load resister in the air bag or a bad connection. I was just wondering if this is most commanly a bad bag.
Old Feb 10, 2007 | 09:08 PM
quicklook2's Avatar
quicklook2
the clock spring may be bad.
does your cruise control work?
you have two sending units in front of the radiator under the rubber strip, these are known to rust away or have a bad ground.
Old Feb 10, 2007 | 10:24 PM
Hawk180's Avatar
Hawk180
Yeah, the cruise control works. The radiator idea could be though, I recently had a radiator leak where the tank was leaking at the top seam where it connects to the core. . I'll check it.
Old Feb 13, 2007 | 09:32 PM
Hawk180's Avatar
Hawk180
Where are the clocksprings located? I have found the sensors, but I cant figure out where the clocksprings are.
miuwcm3
Apr 10, 2014 12:16 PM
h2omotorsports
Nov 14, 2008 04:44 PM
bowhunter123
1983 - 2012 Ranger & B-Series
Aug 27, 2005 07:31 PM
Dville
Aug 14, 2005 10:10 PM
AAS
1978 - 1996 Big Bronco
Nov 9, 2003 05:45 AM
