Trouble Code
Old Feb 10, 2007 | 07:18 PM
Edward Mobley's Avatar
Edward Mobley
Unhappy Trouble Code
My 2003 6.0 diesel just showed a trouble code. P2285 The truck romped for a second and then it ran rough for a few seconds then it showed the code and is doing fine now. This is the first trouble that I have had with the truck. It has 38000 miles and is stock .What could be the problem. Help
Last edited by Edward Mobley; Feb 10, 2007 at 07:20 PM. Reason: I need to add to post
Old Feb 10, 2007 | 07:56 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Check out this posting for your answer.
https://www.ford-trucks.com/forums/5...ighlight=p2285
Old Feb 10, 2007 | 08:02 PM
CanadaGuy's Avatar
CanadaGuy
2003 had major problems with ICP sensors failing and/or developing leaks and sometimes contaminating the wiring. When the ICP signal is inaccurate, then fuelling becomes inaccurate. One quick check is to see if you have any oil running down the left side of the bellhousing area.
Old Feb 10, 2007 | 08:07 PM
bigredtruckmi
Veteran: Navy
Here is another posting
Old Feb 10, 2007 | 09:05 PM
Edward Mobley
Thanks for the info. I will take the truck in this week for the ICP sensor
