Sponsored by: Real Truck
'05 - '07 SD Compass / Temp
Old Apr 27, 2007 | 09:25 PM
wiingnut's Avatar
wiingnut
go on ebay I seen great prices on mirrors. Sometimes you can by used set ups from totals for dirt cheap.
Old Apr 28, 2007 | 07:57 PM
Super08's Avatar
Super08
Originally Posted by jbtraul
I finally ordered and recieved the mirror. Looking at the harness and the firewall, I'm not sure where to go through the firewall with the tempature sensor wires. All the current wire bundles are packed pretty tight through the gromets. Not real hot about drilling another hole. For those of you that have done this, where and how did you go through firewall? Thanks for the help.
Go and look under the hood on the drivers side. On the firewall you should see a foil patch behind/below the brake reservoir. Take a small screwdriver or a piece of coathanger wire and poke a small hole through it. It is very soft like tinfoil.
Old Apr 29, 2007 | 10:33 PM
jbtraul's Avatar
jbtraul
Thanks Super 08, thats what I did. The mirror works great. I had to lengthen the power and the ground wires to get everything to reach. Other than that, this is a simple (but a bit pricey) upgrade.
