TSB 99-20-7 question
Old Feb 9, 2007 | 07:11 PM
motolombardo's Avatar
motolombardo
Cool TSB 99-20-7 question
Doing the intake manifold gaskets and was told to check the tsb for new torque values. The tsb says to torque to 71 lb-in. OK sounds good. the next half of the sentence says to then tighten all bolts an additional 90 degrees. wtf? In two years of working on airplanes and 3 on motorcycles ive never seen a torque value that tells you to tighten to a specific value then to just go on ahead and give 'er a good 90 degrees. Should I just go ahead and stick with the haynes recomendation if 44 then 89 lb-in. ?? why would they give you a value as specific as 71 lb-in then tell you to tighten an additional 90 degrees? just a few degrees of turn can add quite a few lb-in of torque.
Old Feb 9, 2007 | 11:57 PM
Racerguy's Avatar
Racerguy
A lot of engine bolts now are "torque to yield".
For some info on this take a look at http://www.canadiandriver.com/articles/jk/040303.htm and http://www.robbos.com.au/myweb/Tech_Bolts.htm . Those were just the 2 sites that came up first with a Google search.
You should try torquing some head bolts where they want 2 X 90 degrees. I'm reasonably strong but have a hard time sometimes. They feel like 250 ft. lbs!
99ExpyProblems
Sep 1, 2018 07:45 AM
Encho
Mar 3, 2016 02:45 PM
Rockledge
1983 - 2012 Ranger & B-Series
17
Oct 30, 2015 08:19 AM
jas88
Jul 20, 2015 07:50 AM
MarksMedicated
Oct 18, 2014 01:06 PM
