How fast am I going?
Old Feb 9, 2007 | 06:06 PM
live2hunt's Avatar
live2hunt
More ???'s . . .
'93 Ranger w/4.0L, 3.27 ratio, and it came with 31X10.5/15's.
How fast am I really going when speedometer is at 40~50~60~etc?
Old Feb 9, 2007 | 06:24 PM
RangerPilot's Avatar
RangerPilot
Depends on what rear end gearing it was originally set for, and if the gearing was changed with the tire change.
Look on your driver's door and decode the original axle ratio from this:
https://www.ford-trucks.com/article/...r_Decoder.html
If the 3.27 was stock and is still in there (and I'd HIGHLY suggest regearing, your effective ratio is 2.74):
Actual / Indicated
20 / 16.8
30 / 25.1
40 / 33.5
50 / 41.2
60 / 50.3
70 / 58.7
Old Feb 9, 2007 | 09:37 PM
sjwoody's Avatar
sjwoody
Drag out your (or your buddy's) GPS and compare it's speed to your speedometer. I bought a 94 last summer and found the indicated speed was faster than the speed shown on the GPS. At the time it had 30X9.50R-15's. I put new 31X10.5R-15's on and the GPS speed and speedometer speed now match exactly. The nylon gear where the speedo cable goes into the tranny was color-coded yellow, which I think is stock, but I'm not sure.
Old Feb 9, 2007 | 11:37 PM
Hank85713's Avatar
Hank85713
find a straight road for about 5-10 miles where you can run a constant 60 mph indicated, use a watch/stop watch to time how long it takes ya to go whatever distance you can and then calibrate your vehicle yourself. Do search for conversions MPH and it will have the ability to tell you your speed based on time and distance.
I changed the speedo gear in mine, made everything worse so went back to the stock one found I was 5mph slow indicating and off about 4 miles per 100 in distance. So 65 = 70, 100 miles = 104.
I later verified with a borrowed gps unit on the speedo.
Old Feb 9, 2007 | 11:40 PM
Hank85713's Avatar
Hank85713
try http://www.gazza.co.nz/distance.html
Old Feb 10, 2007 | 11:03 AM
live2hunt's Avatar
live2hunt
That would explain why I'm doing 40 in town or 75 on freeway and passing every one . . .
Well, not everyone.
Old Feb 10, 2007 | 11:25 AM
BSmitty's Avatar
BSmitty
Doesn't FTE have a tire change calculator? If not, TRS does, you can use theirs. You enter the SAE measurements of your stock tires, then your new ones, and a given indicated speed, and it will calculate the actual speed you are travelling. It's useless if you've changed your gearing as well though.
Old Feb 14, 2007 | 11:00 AM
live2hunt's Avatar
live2hunt
According to the door tag, it is 3.27 rear end.
I am curious, why would I regear and to what?
