1978 - 1996 Big Bronco
94 bronco needs some help!!
Old Feb 9, 2007 | 02:19 PM
hntr8183's Avatar
hntr8183
Question 94 bronco needs some help!!
Hi everyone i got a 94 bronco with a 302 in it. Last year i swapped my auotmatic tranny for a 5 speed. Since then i lost my 4WD low and my reverse lights. Does anyone know if there is a wiring harness made to plug into the old automatic harness and goes into the new 5 speed? Another question i have is i got a weird clunking noise comming from the front end. It does it when i hit bumps and when i tap on the breaks. I put new rotors and ball joints on and the clunk is still there. i have no idea where its comming from. Any info and help would be great its drivin me insane. Thanks
Old Feb 9, 2007 | 02:54 PM
rods4life's Avatar
rods4life
Sound to me that the clunking could be from worn bushings in your control arms.
Old Feb 9, 2007 | 05:08 PM
hntr8183's Avatar
hntr8183
Thanks alot i will have to check it out.
Old Feb 9, 2007 | 05:15 PM
Mustang_68_Coupe's Avatar
Mustang_68_Coupe
Check your shock mounts, too.
Old Feb 9, 2007 | 10:51 PM
ag30265's Avatar
ag30265
Both the broncos I own used to do the front end clunk. It took me a year and a half to figure it out. I don't know if it's your problem but I had to replace the radius arm bushings. About a year later my '87 started doing the same thing again. I replaced the bushings again but this time I spent the money and went with polyurethane bushings and haven't heard it since. I've heard of that problem from several people and I thinks it's pretty common. I don't know about the harness but if you can get a wiring diagram for the original harness you should be able to split the harness and run the wires to make your lights work, and as for the 4lo you already cut a hole for the shifter so why not upgrade the trans. case and get a manual shift so you can control the 4x4 and not the computer.
Old Feb 10, 2007 | 11:03 AM
hntr8183's Avatar
hntr8183
Thanks for all the info guys. i will have to look into everything you said.
scottjima
Jan 15, 2018 09:33 PM
powerstroker04
Oct 4, 2015 11:00 PM
jeffmfly1
Mar 3, 2010 07:49 AM
Squiggy
19
Jul 13, 2007 08:28 PM
Rat
Aug 13, 2004 02:02 PM
