Rant
Old Feb 9, 2007 | 11:44 AM
1969fordguy's Avatar
1969fordguy
Rant
AAAAHHHHHH!!!!!!!!! Stupid truck! Left me stranded. No start this morning. It cranked and the tach moved. It smoke white plenty. After waiting for 90 seconds on the 3rd try it hit, but would not start. It did this several times. It still spun pretty good, but I gave up before I killed the battieries. Alright I didn't get stranded. My girlfriend took me to work. Perhaps it will start this evening when I get off work. I hope it is fuel that has gelled, or whatever it does when it gets too cold. Yeah I know, I should have put an additive in it. It has a fresh tank of fuel in it.
Hmmmm. I thought getting this out would make me feel better, but I'm still stewing over it. *&$%*& it!!
I'll let you guys know what happens...
Old Feb 9, 2007 | 12:10 PM
ruger761's Avatar
ruger761
If its real cold try plugging in the block heater for a few hours, make it start a little easier in the cold. If that helps then its time to replace the glow plugs and possibly the glow plug relay.
Old Feb 9, 2007 | 12:14 PM
Cuda_jim's Avatar
Cuda_jim
I hope you put a charger on the batteries. Dead batteries+cold temps=frozen batteries.
Old Feb 9, 2007 | 03:50 PM
1969fordguy
<TABLE class=tborder cellSpacing=1 cellPadding=4 width="100%" align=center border=0><TBODY><TR title="Post 4406118" vAlign=top><TD class=alt1 align=middle width=125>Cuda_jim</TD><TD class=alt2>I hope you put a charger on the batteries. Dead batteries+cold temps=frozen batteries.</TD></TR></TBODY></TABLE>
Great give me something else to worry about! The truck is at my girl's apartment complex, so it didn't get plugged in or charged any. I'll see what happens here in an hour or so.
Old Feb 9, 2007 | 04:24 PM
Cuda_jim's Avatar
Cuda_jim
Sorry, didn't mean to add to your worries. Takes a while, like overnight with below zero temps. Even if they did freeze (slush up) no damage will be done just as long as the case doesn't break.
Old Feb 9, 2007 | 06:09 PM
1969fordguy
Whew! The big turbo diesel started on the second try this evening. Made a massive smoke cloud from all that unburned fuel. I put some winter blend diesel kleen in it too, 'cause its gonna be cold again tonight.
Thanks for the replies guys~
Old Feb 9, 2007 | 08:03 PM
rusty9cab's Avatar
rusty9cab
Mine takes awhile to start in the cold when it has been sitting all night. Probably time to check the gpr.
Old Feb 12, 2007 | 07:16 AM
1969fordguy
How long should a GPR last? I replaced mine 2 years ago, along with all the glow plugs.
Old Feb 12, 2007 | 09:06 AM
Cuda_jim's Avatar
Cuda_jim
It depends on the GPR. Some last 1 winter, others go for years. I use the GPR110, seems to be the best deal.
Old Feb 12, 2007 | 09:07 AM
Cuda_jim's Avatar
Cuda_jim
