Block heater location???
Old Feb 9, 2007 | 09:36 AM
PERFORMANCE RED's Avatar
PERFORMANCE RED
My sisters 05 Sport-trac was orginially boughts in Michigan and then bought on auction and shipped to Minnesota. In both of these states the, i thought, the block heater was standard equipment. If it is on there i can't seem to find it.
Where should i be looking for the plug in if it was equiped with the block heater? Or where would the actual block heater be located?
Old Feb 15, 2007 | 03:38 PM
PERFORMANCE RED
Nobody is willing to go take a look at there truck for me?
Old Feb 15, 2007 | 03:51 PM
Backin72's Avatar
Backin72
I don't have an 05 sport trac, but if it has a block heater, it'll be in one of the frost plugs on the engine block. What I think you are looking for though is the cord to plug it in. Look around the battery or it may be tucked up under something or tie strapped to a hose or other cable. Look for a flat type cord, three phase, that looks different from all the rest of cables and junk under the hood.
Old Feb 15, 2007 | 03:59 PM
quicklook2's Avatar
quicklook2
i doubt that it was standard equipment.
Old Feb 17, 2007 | 05:57 PM
426's Avatar
426
The factory block heater should be located on the passenger side of the lower grill. It's a small sping loaded plastic cover. Lift it up and you will see a three prong male plug. The block heaters are standard on all Explorers headed to Canada.
Old Feb 17, 2007 | 07:59 PM
quicklook2's Avatar
quicklook2
but not standard in michigan.
Old Feb 17, 2007 | 08:08 PM
169STANGSTER's Avatar
169STANGSTER
in general block-heaters are a "option" in most states. As stated in other replys blockheaters are located in various welch-plug (freeze-plug) holes in the outer water jacket side of the molded engine block. If your vehicle does not have one, they are retelitivy easy to install and available at most national parts providers.
Bigtruc
33
Dec 5, 2023 12:27 AM
Tom
2015 - 2020 F150
34
Jan 30, 2016 07:38 AM
L121andrew24
Jan 7, 2016 05:43 PM
Joe Lallande
2015 - 2020 F150
Sep 1, 2015 08:58 AM
Barret88
Jan 25, 2014 07:02 PM
