mannual transmission
Old Feb 9, 2007 | 08:50 AM
ncfirefighter46's Avatar
ncfirefighter46
hello everyone, does automatic transmission fulid go inthe zf tranny? and has anyone add lucas oil stablizer too it ?
Old Feb 9, 2007 | 09:25 AM
pottymouth2's Avatar
pottymouth2
My '05 uses ATF in the ZF-6. I would not put an additive in the tranny fluid, unless you are experiencing problems.
Old Feb 9, 2007 | 04:48 PM
Winger235's Avatar
Winger235
ATF in the ZF5 no additives the tolerances in those transmissions are tight. No additives. They foam and and make a mess and air in the oil actually decreases your surface area of lubrication. I recommend synthetic ATF.
