Ih 9.0
Old Feb 9, 2007 | 04:31 AM
Cool6.9DieselGuy's Avatar
Cool6.9DieselGuy
Ih 9.0
anyone ever play w/ one of these school bus engines, the International Harvestor 9.0 from the 80's? I'm wondering how much of a chore it would be to fit one under the hood of an f350 and get her going...
Old Feb 9, 2007 | 05:28 AM
tjc transport's Avatar
tjc transport
i ain't rite
the 9 liter engine was problem engine for international.
my buddy replaced 15 of them with 466 powered busses after only 1 year due to repeated head gasket failure.
Old Feb 9, 2007 | 06:37 AM
mechmagcn's Avatar
mechmagcn
I was working for IH when these engines were introduced. Between head gasket failures and excessive oil use, most didn't last long. The major problem we found with oil use was missing rings on the pistons This is no joke.I don't know who was building these things or who was in charge of quality control, but they were not doing their job.
Old Feb 9, 2007 | 02:24 PM
Dave7.3's Avatar
Dave7.3
If you really want to do a project like that, I think the Ford 7.8L that you find in heavy duty trucks would do a little better in the F350 Frame. Sits a little higher and is a little longer but alot easier to fit than that big 9.0L would...
Old Feb 9, 2007 | 02:51 PM
tjc transport
i ain't rite
Dave, are you talking about the Brazilian six cylinder??
those things are not much better. if the oil pump wears out, you throw the engine away, cause you can not get a new one. i lucked out and was able to rebuild it, but the next time i am up the Creek.
Old Feb 9, 2007 | 04:04 PM
Winger235's Avatar
Winger235
The old 9L they did sound pretty tough. Gutless fuel chewing dogs but sounded cool. They were the 545 gas engine convertion. The blocks were tough and if you got through the 1st overhaul with updated heads etc they wern't to bad. They were the best cold starting diesels I ever dealt with. They came with the ether cold start assist on the rigs we used but they were never used. I worked for a School Bus garage part time and we had a mixture back then. 6.9L, 7.3L. DT466 and the 9.0L. On the below zero days all but the 9.0L needed to be plugged in overnight or slave started in the morning. Not once did we have a problem with starting them. Other problems though some head gaskets must have got lucky we had all our piston rings. But fuel wow bring your wallet! The engine would fit but she weighs in around 1700-1800 lbs as I recall. The exhaust pipes would have to go on the outside of your frame right from the manifold. They did on the passenger side on a school bus and that side seemed to crack the exhaust manifold. Had the pleasure of changing a few.
I would say a lot of work from start to finish and beyond.
Old Feb 10, 2007 | 05:47 AM
Cool6.9DieselGuy
maybe a monster like taken to stage 3 and dropped in a ford would make a hell of a drag racer but I think I'm done toying w/ the idea......
