battery cables
Old Feb 6, 2007 | 07:35 AM
knapikmichael's Avatar
knapikmichael
battery cables
where xcan i get a cable that is better than the oem and better than the stuff at auto zone have very weak connection on the starter to batteryto the secondary its a huge cable and i only want one terminal
Old Feb 6, 2007 | 08:05 AM
PLC7.3's Avatar
PLC7.3
Auto zone will build them or build your own ...... http://www.mcmaster.com/ search for battery cables.
Old Feb 6, 2007 | 12:37 PM
Bullitt350's Avatar
Bullitt350
You can try here: http://http://lmctruck.com/icatalog/fd/0128.asp
Also, you make your own by getting cable from a welding supply business and solder some 2/0 battery terminals on to them. That's what I did, made 3 new battery cables for about $60.
Old Feb 6, 2007 | 02:18 PM
brownieboy525's Avatar
brownieboy525
custombatterycables.com there cables are very high quality
Old Feb 6, 2007 | 03:41 PM
fonefiddy's Avatar
fonefiddy
Yep, I'll second custombattercables.com
The best you'll find for these trucks. I've got them and couldn't be more impressed or more happy. I even picked up about 2-300 cold cranking RPM's My truck has new batt's custombatterycables.coms, and a rebuilt Hitachi starter. It spins sooo damn fast, it's crazy.
I started it @ -15 with no block heater, one cycle of the gp's and about 2 seconds on the starter!
Old Feb 6, 2007 | 08:09 PM
Dave Sponaugle's Avatar
Dave Sponaugle
NAPA can also make cables at most locations.
2/0 cable from the passenger side battery to the drivers side battery.
3/0 cable from the drivers side battery to the starter.
I had NAPA make me two cables, one from each battery to the starter.
I still used the stock wire size for the cables though.
Old Feb 9, 2007 | 05:20 PM
knapikmichael
ill stick with daves idea it sounds good and napa is down the the road
Old Feb 10, 2007 | 07:55 AM
DSSinc's Avatar
DSSinc
http://www.jcwhitney.com/autoparts/P...000921/c-10101
Just my .02¢
