Sponsored by: Auxito
Front Differential ID Tag
Old Feb 8, 2007 | 10:55 PM
jvaski's Avatar
jvaski
Smile Front Differential ID Tag
98' F150 4WD 5.4L
Front Differential ID Tag reads;
S 976 B
355 88 7J10
Ok, I assume the gear ratio is 3.55 and th ring gear is 8.8" correct ?
What do th rest of the rest of the numbers mean ?
Does anyone know where I can purchase a good quality reman. front diff assy ?
Thanks,
JA
Old Feb 9, 2007 | 12:47 AM
Racerguy's Avatar
Racerguy
The S 976 B is a "stamping" number. If you need parts for the diff that's the number to give your dealer.
It's an 8.8 with 3.55s like you assumed.
The 7J10 is a build date code.
Old Feb 9, 2007 | 10:27 AM
jvaski's Avatar
jvaski
Diff ID tag
Thanks for confirming that Racreguy !
Lost the driver's side output bearing , looking for a used or rebuilt replacement.
Weird that this bearing went out - hardly ever used 4WD.
eduhat
Dec 22, 2015 06:29 PM
joegeds
Oct 5, 2014 09:23 AM
trailrider121
51
Feb 20, 2012 04:22 PM
fordbii
Mar 13, 2004 10:44 AM
93superflare
Feb 29, 2004 02:30 PM
