am i over-boosting?
Old Feb 8, 2007 | 10:16 PM
fcfirefighter05's Avatar
fcfirefighter05
am i over-boosting?
Sorry about asking this because i'm sure this has been answered many times, but I haven't found the answer yet. I just put the boost and pyro gauges on my truck. I modified my EBPV by adding a spring to resist it opening as soon (takes about 9-10 psi to open instead of 5 psi). So on to numbers, it was hitting 25 psi on boost tonight and I would rather back the turbo down if I'm too high so as not to blow apart something. Any input will be greatly appreciated! thanks
Old Feb 8, 2007 | 10:21 PM
CSIPSD's Avatar
CSIPSD
You added something to the wastegate, not the EBPV... If you added something to the EBPV then you did nothing for your boost numbers.
25#'s is fine, you can run all day at 25#'s You can spike to 30 every now and then and be fine.
Old Feb 8, 2007 | 10:22 PM
fcfirefighter05
Sorry, thats what I ment to put, but yeah you're right, it was the wastegate
Old Feb 8, 2007 | 10:25 PM
CSIPSD's Avatar
CSIPSD
Na, your fine, if you dont have a boost regulator or blow off on the MAP sensor you will defuel at around 22-25#'s anyway...
