Idle problem....possibly EGR?
Old Feb 8, 2007 | 03:17 PM
nighthawk285's Avatar
nighthawk285
Ok, so I have been looking at trying to fix a rough idle problem for quite some time now, I've done the pull vacuum lines and plug the tree, then one by one put em back on, but that didnt show anything. So I started spraying light mists of starting fluid everywhere, and when I spray it near and into these holes in the EGR valve, the idle kicks up. Is this where my leak is? What is in there that would make it do that?
Thanks in advance
Old Feb 8, 2007 | 06:50 PM
mhg's Avatar
mhg
one of 2 possibilities
the vacuum diaphram is bad
pull vacuum line and block off
if idle is better replace egr
if not then valve may have carbon build up
holding it open and allowing exhaust into
the intake
to fix remove the valve and clean it out
or replace as needed
Old Feb 8, 2007 | 08:29 PM
nighthawk285
thanks, will try
Old Feb 8, 2007 | 09:55 PM
nighthawk285
ok, pulled the green vacuum line and blocked it off. No different. Pulled EGR off and it works just fine, I can move the valve with little effort by applying vacuum to the tube, but there is a lot of carbon in there so how do I clean it?
More info on the idle problem....its not high, it sits at 1000 when I let off the throttle, then it goes down to 700 and starts sounding like theres a big cam in it with an extremely lopey idle, bouncing around from 600-800.
But when I pulled the EGR and put my thumb over the hole in the intake, the idle was fine and it ran perfect, so Im guessing it needs to be cleaned?
Old Feb 9, 2007 | 02:35 AM
nighthawk285
another thing to make note of here before bed, but when it had the really lopey idle in it, the exhaust smelled really really rich to me, any connection?
Old Feb 9, 2007 | 07:07 AM
EPNCSU2006's Avatar
EPNCSU2006
Lopey=inefficient combustion which will leave more un-burned fuel in the exhaust, making it smell rich. Just a thought anyway.
Old Feb 10, 2007 | 06:45 PM
nighthawk285
thanks, put on a new EGR today and got everything working, runs great, thanks for the help
Old Feb 11, 2007 | 03:02 PM
EPNCSU2006's Avatar
EPNCSU2006
Good to hear it and glad you got your truck running right again
