What are the differences in 7.3PS?
Old Feb 8, 2007 | 01:04 PM
Supergordo's Avatar
Supergordo
Hi Everyone,
Im new to the forum and the power stroke motors. Im trying to do my homework and im researching to learn more about these cool powerplants.
This forum is a cool resource though i havent really scratched the surface yet.
I'm trying to learn the major differences between the 94-98 7.3 and the 99-03 7.3. Im curious to the differences in the power they produce and why. As well any opinions you all have since your driving them.
Thanks everyone!
Gordon
Old Feb 8, 2007 | 01:25 PM
westpsd's Avatar
westpsd
Basicly the same engine, just differences in bolt ons and controls. The early models have smaller injectors, smaller turbo, no inner cooler, and less HP tuned into them. They are just as dependable though and can make the same HP as the later models, it just costs more for the additional mods. Someone with more knowledge than I will add to the list of differences. There is also subtile differences in the transmissions. They are basicly the same, just more refined as you get newer.
Old Feb 8, 2007 | 07:11 PM
CSIPSD's Avatar
CSIPSD
There is the OBS Powerstroke...94-97, no intercooler, 90cc injectors, 15 degree HPOP (Hi pressure oil pump), smaller turbo, and a E4od tranny in the autos and a 5 speed man. Stock form about 190 to the rear wheels
The early 99 trucks, intercooled, small turbo (bigger then the OBS but) 120cc injectors, and most had the smaller 15 hpop, 4r100 auto tranny and a 6 speed man... about 220 to the rear wheels stock...
Late 99 to 03 trucks, 140cc injectors, bigger turbo but it likes to surge, 17 degree HPOP... about 220 to the rear wheel stock...
Old Feb 9, 2007 | 01:32 AM
Supergordo's Avatar
Supergordo
Thanks guys! Are the turbos and injectors and all that stuff interchangeable? Can you upgrade the engine for more power if you want?
Old Feb 9, 2007 | 06:04 AM
bdrummonds's Avatar
bdrummonds
Yes, BUT, depending upon what what year you have some mods are not plug and play, other things must be upgraded to support the mods. What I mean is you can't go throw 140cc injectors on a 94-97 , and expect to gain a bunch of horses without getting tunes for the engine and upgrading the oil system.
Upgrading a 7.3 PSD is not a quick and easy process, it takes time, and patience, and then after you upgrade it there is still a good chance that a 6.0 will beat you in a drag race but can he do it after he has 200k miles on his truck.
Old Feb 9, 2007 | 08:03 PM
Supergordo's Avatar
Supergordo
Thanks guys, i appreciate the education here! Great info!
Old Feb 9, 2007 | 08:46 PM
aklim's Avatar
aklim
Late 01 they changed to Powdered Metal Rods because they were too cheap.
Old Feb 9, 2007 | 09:05 PM
Supergordo's Avatar
Supergordo
So would you say you prefer the eariler PS?
Old Feb 9, 2007 | 10:35 PM
aklim's Avatar
aklim
Hell yes!!! I wouldn't change it in mine right now but if I knew then what I know now and had the choice, you bet. Forged rods will hold up to over 400HP while you had best keep it under that for PMR.
Here is how to check.
I think that link is down for now. Will see if it is back later. Do a search for Powdered Metal Rods and you will be told
Old Feb 9, 2007 | 10:51 PM
Tenn01PSD350's Avatar
Tenn01PSD350
For all the PMR talk here, 400 is a lot of ponies. I would venture a bet that despite all the hullabaloo about it here, about 90% or better here are nowhere near the 400hp mark. Think that over. A 350+ hp rig will make gobs of torque and with the proper tranny mods will satisfy all but the most hard core folks.
The 6.0 has become an impressive powerplant but resides in a more expensive truck and is close to maxed out from the plant. It responds well to light mods but because it is about maxed out by design, it will experience longevity issues when modded. JMO. BTW, it is being replaced. It's all about emissions.
I would stay away from the earlier 7.3s if you want to get up and go, but if you want to pull the load they are still doing it quite well. I see them all the time. Great engine that 7.3.
Old Feb 10, 2007 | 11:30 AM
CSIPSD's Avatar
CSIPSD
Get your facts straight... Ford did not change to PMR's due to cost. It was to lighten the rotating mass and quiet the motor... There is nothing wrong with PMR rods. There in the 6.0 and holding over 700hp...
There mistake (Fords) was in not redoing the tooling when they made the switch. You have to add matterial and can remove matterial in a PMR type casting...
And as the above poster said, it takes ALOT to get to 400hp... With everything I have done I am just over 400hp...
Old Feb 10, 2007 | 12:11 PM
mrfixit64857's Avatar
mrfixit64857
The new 6.4s are said to be VERY resistant to mods, with interlocks and flash programming codependent... be interesting to see how this develops!
Old Feb 10, 2007 | 12:14 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Where did that reply come from?
Old Feb 10, 2007 | 12:20 PM
mrfixit64857
Sorry... think I was mixing my replies with another thread, lol.... consider that an accidental post!
Old Feb 10, 2007 | 01:33 PM
aklim's Avatar
aklim
So why are we told not to go over 400 with PMR then?
