What are the differences in 7.3PS?
Old Feb 10, 2007 | 04:57 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
It all has to do with correct tuning. You can have custom tunes designed to lower combustion pressures by injecting fuel later than normal. But with the wrong programming (or using propane/nitrous without proper tunes) the CP's get too high. The problem with the PMR's is that they are identical to Forged rods in I beam and end cap shape, and they should be stronger in some parts to compensate for the casting weakness opposed to forging. They get a stress fracture from overrevving or too-high CP's and then later on they just window a block.
