head scratcher for you
Old Feb 7, 2007 | 08:53 PM
jyccustoms's Avatar
jyccustoms
Question head scratcher for you
i have a 97 F-250HD,351W,E4OD,2WD,XLT.well on my way to my sis house,my ignition coil to dist burned in half,i fixed the wire and went on my way but the trany started to shift hard.about 100 miles later the truck started to lose power.
then over the course of 30 miles the truck graduly lost all power and died.if i let it set for 30 minuts it would start back up but wouldnt rev over 2000rpm.it would run for 5-10 min then die.now it wont start unles i floor the throttle,then it starts revs up to 1200 and stalls.it has new injectors,ecm,plugs,wires,cap,rotor,fuel filter.any input i can get would be great.
thanks alot
RICK
Old Feb 7, 2007 | 09:45 PM
Conanski's Avatar
Conanski
How much fuel pressure does it build?
Old Feb 7, 2007 | 09:50 PM
jyccustoms's Avatar
jyccustoms
about 35-40 psi
Old Feb 8, 2007 | 06:24 AM
subford's Avatar
subford
Replace the resistance wire that burnt or put in two Chrysler Ballast 0.5-Ohm resistors wired in series in place of the wire.
You can get them at any Auto Parts store.
It takes special connectors used for high temperatures available from appliance repair shops. They use them for wire connections to heating elements.
The standard crimp connections found in auto stores will not last long with the heat exposure in these connections.
Do NOT install it under the dash. Install the resistor under the hood on the firewall, and then run the wires to them there. This will provide airflow and keep the resistor cooler, and possibly prevent an under dash fire.
Then replace the Ignition Coil, it is toast.
Old Feb 8, 2007 | 01:16 PM
jyccustoms's Avatar
jyccustoms
new coil,it was the plug type wire that burnd in half.the truck has solid spark.the hole ign syst has tested good.
Old Feb 8, 2007 | 04:41 PM
jyccustoms's Avatar
jyccustoms
BUMP
Old Feb 8, 2007 | 04:54 PM
subford's Avatar
subford
Sorry I misread your first post and though you were talking about the resistance wire.
Disregard my post above.
Old Feb 8, 2007 | 05:04 PM
jyccustoms's Avatar
jyccustoms
no prob........got any ideas?
Old Feb 8, 2007 | 05:05 PM
jyccustoms's Avatar
jyccustoms
im about ready to put in a 7.3 idi turbo with a zf
Old Feb 8, 2007 | 06:02 PM
subford's Avatar
subford
Pull your codes and check the TPS.
TPS - Throttle Position Sensor
Old Feb 8, 2007 | 06:55 PM
jyccustoms's Avatar
jyccustoms
no codes,tps new.changed it when i changed injectors since i had the plentum of anyway
Old Feb 9, 2007 | 04:26 PM
jyccustoms's Avatar
jyccustoms
ahy ideas at all?????????????
Old Feb 9, 2007 | 04:42 PM
skyfox10's Avatar
skyfox10
no codes in CM or KOER?
i have no idea
Old Feb 9, 2007 | 04:46 PM
jyccustoms's Avatar
jyccustoms
i think the truck is still mad at me.must be time for a 7.3 idi and a zf.
Phillip Guidry's Avatar
Phillip Guidry
Plugged up exhaust ? Jumped timing ?
Phil
