Manitoba / Saskatchewan Chapter Join Chapter, Leader: Fomoko1
Dueller-Flat Head VS 390 weight?
Old Feb 7, 2007 | 08:32 PM
Fomoko1's Avatar
Fomoko1
I believe the 390 is abit heavier, is it and how much?
Old Feb 7, 2007 | 08:39 PM
51dueller's Avatar
51dueller
Flathead V-8 = 570 lbs
390 FE = 650 lbs
And my little 302 weighs 450lbs.
Old Feb 7, 2007 | 09:23 PM
Fomoko1's Avatar
Fomoko1
So with Alum heads, intake and headers it would be close...
Just a matter of $$$.
Old Feb 7, 2007 | 10:34 PM
Snowking's Avatar
Snowking
Fom can I have he old flattie? I always need a new base to start from, one the was running that'll be easy.
Old Feb 8, 2007 | 06:57 PM
FirstTry's Avatar
FirstTry
i thoight my 352, all iron weighed about 700lbs. and it would be just about the same as a 390 correct?
Old Feb 8, 2007 | 07:16 PM
Snowking's Avatar
Snowking
I was under the impression a V4 wiscounsin tipped the scales at 400lbs.
Old Feb 9, 2007 | 12:32 AM
Fomoko1's Avatar
Fomoko1
Same block and heads, basically same engine with a short stroke/smaller bore.
Old Feb 9, 2007 | 12:36 AM
FirstTry's Avatar
FirstTry
yeah and that was a heavy sucker, had to weigh more than 570lbs. i thought with the 3spd it was over 900
Old Feb 9, 2007 | 10:21 AM
Snowking's Avatar
Snowking
the 352 is a higher compression motor then the 360/390.
The 352 is quite close to a 360 If you bore a 352 .060 you have a 360.
Old Feb 9, 2007 | 06:06 PM
Fomoko1's Avatar
Fomoko1
Boring a 352 out .060 sounds like alot!
I wanted to bore a 390 by .80 to make a 428 with the 428 crankshaft but was advised against that.
Old Feb 9, 2007 | 06:21 PM
Snowking's Avatar
Snowking
or is it .040 hmm never been good at math. Really .060 is the max for a street vehichle any larger and overheating my become a issue. Most magazines sell pistons up to .060. (NPD for example)
I'll take a look in my book.
Ok Chiltons to the rescue,
a 352- 4.000x3.50
360- 4.05x3.50
390- 4.05x3.78
hence simple math .050 overbore will give you a 360.
Old Feb 9, 2007 | 06:26 PM
FirstTry's Avatar
FirstTry
when i was in teh FE forums there was something mentioned called the drill bit test. i thought using that test on a FE motor gives you an idea how far you can overbore (if its a good block) because from a semi educated perspective, a 352 could be bored to a 428, even though it actually cant.
theres so many goofy things about this family
Old Feb 9, 2007 | 06:34 PM
Snowking's Avatar
Snowking
yikes that one is out of my league. When you bore and get new pistons and all that fun stuff for a 352 would a motor loose that extra compression?
because Chiltons says the 352 is a 8.9 motor where as some of the late 360/390's were around the 8.2/1.
Old Feb 9, 2007 | 06:51 PM
51dueller's Avatar
51dueller
You got to remember that the 352 was discontinued before the smog regulations were imposed on engines.
Old Feb 9, 2007 | 07:19 PM
Snowking's Avatar
Snowking
That's what makes em better?
