Ok...um I need some help
Old Feb 7, 2007 | 07:03 PM
jvoigt's Avatar
jvoigt
Unhappy Ok...um I need some help
Ok so I found this yellow switch behind the fuel filter.......well I just had to see what it does so I flipped it and about a cup of diesel came out of a drain tube. I didnt get a owners manual for the diesel so I am not sure what it is and what I did...Did I "F" something up? I noticed when I turned the key to on position the fuel pump sounded like its was guzzeling some airbubbles, it did this for about 8 cycles then I decided to just start it up and take it out and get on it a little to work the air out of the pump. Is that bad? I mean can you just flip that switch with out changing the filter and then just go about busesness as normal or do you need to do any other special steps after flipping the switch?
Old Feb 7, 2007 | 07:08 PM
johnsps250's Avatar
johnsps250
Yes, no worries. If anything you drained any water that might have been in the separater. Just close the valve and go about your business,
Old Feb 7, 2007 | 07:09 PM
fxstbchopper's Avatar
fxstbchopper
That is not a switch it is the drain valve for the fuel filter housing you open it to drain the fuel to change the filter the pump runs more because it is filling the filter and housing back up it is not going to hurt anything just make sure you close it when your done with the filter change.
Old Feb 7, 2007 | 07:12 PM
jvoigt's Avatar
jvoigt
AWWW so thats what that switch does, well thats a relief so now why would the fuel pump sound like its got air in it when I cycle the key to on and the pump is primeing? i guess its primeing the fuel system. It doesnt do it now but after you drain the separator do you have to prime the fuel system?
Old Feb 7, 2007 | 07:13 PM
Uzumati's Avatar
Uzumati
And keep an eye on it they have been prone to springing leaks from the o-ring seal since the switch to ULSD.
Old Feb 7, 2007 | 07:15 PM
fxstbchopper
No it sure be primed by the time the wait to start light goes off.
Old Feb 7, 2007 | 07:21 PM
jvoigt's Avatar
jvoigt
Thanks for the info/help
vernon_25
Bio-diesel, Propane & Alternative Diesel Engine Fuels
15
Dec 21, 2010 04:04 PM
Storm
May 21, 2007 09:23 PM
harria3
Aug 23, 2004 09:26 PM
lyle1
Jul 12, 2004 07:44 PM
