1972 302 electric choke question
Old Feb 7, 2007 | 03:49 PM
goodwrench's Avatar
goodwrench
Okay i have a 1972 302 standard two barrel carb. Right now the heat tube choke is brain dead. Can i just get the electric choke cap and stick it on? Like this one http://www.partsamerica.com/ProductD...pe=274&ptset=A? And then what is the difference in a 72 electric choke cap, and a 73? http://www.partsamerica.com/ProductDetail.aspx?mfrcode=GPS&mfrpartnumber=77913 12&parttype=274&ptset=A? Any pointers on this guys!! will changing the caps work?
later!! chris
Old Feb 8, 2007 | 06:34 AM
d79f150's Avatar
d79f150
Go to the parts store - don't order the choke online first of all...
There are numbers in the carb that need to match the choke, you'll find them somewhere on the top or side in a little metal tag. Write them down and take them to the parts store and they will get you the correct choke for your 302. Just slapping a choke on a carb that doesn't necessarily fit the application will only cause you more headaches.
Old Feb 8, 2007 | 07:57 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
9819 Choke stove tube 302
Ford part number:
C8OZ-9819-D Kit, Choke Stove Tube 1968/72 F100 302
Buying a new electic choke will prolly not get you the choke (stove) tube. They come separate.
Most auto parts stores sell a choke stove tube repair kit. It's composed of the tube, insulator and nut/ferrule(s).
Old Feb 8, 2007 | 08:50 AM
goodwrench's Avatar
goodwrench
electric chokes do not require the heat stove. Mine is just fine anyway. The darn thing just dont work worth a durn. I want to convert it to electric..
later chris
f100today
Jun 8, 2016 07:39 AM
rkeith213
Feb 23, 2015 05:29 PM
96_4wdr
Aerostar
Oct 26, 2007 09:41 AM
COLEnMICHAELS66
Mar 8, 2006 10:02 AM
