Sponsored by: Real Truck
Where to get Wheel Alignment Checked?
Old Feb 7, 2007 | 12:34 PM
usdave1t's Avatar
usdave1t
Cool Where to get Wheel Alignment Checked?
I have a 2004 F250 crew cab, short bed with a 6 inch lift. I need to get my wheel alignment checked but am having difficulty finding somewhere to do it. So far I have been to Pepboys, Goodyear, Firestone......they all said the truck is too big for them to do it. None of them could suggest anywhere either!
Anyone got any ideas? I live on the west side of Houston, TX so somewhere not too far from there would be great.
Thanks!
Old Feb 7, 2007 | 01:15 PM
redford's Avatar
redford
FTE Leadership Emeritus
hate to say it, but you might call your dealer......
Old Feb 7, 2007 | 02:49 PM
usdave1t's Avatar
usdave1t
Yes I could, but I am somewhat less than impressed with the dealer - actually I think he pretty much sucks! I was trying to avoid going to him, but I guess I could go to a different dealer.....
Old Feb 7, 2007 | 03:15 PM
jim henderson's Avatar
jim henderson
I had the same problem with my 94 F250. You will have to ask around to see who might do it. Try a tire dealer that doesn't have an alignment shop. They might recommend someone. Some mechanic shops also would know a good alignment shop.
Most dealers I checked did not do 4 wheel alignments which surprisingly you should get for your truck.
Good Luck,
Jim Henderson
Old Feb 7, 2007 | 03:55 PM
JGRNAUT_7.3L's Avatar
JGRNAUT_7.3L
Just went through this with my truck. Finnaly found a offroad truck place that did them. Call around and ask them if they have an extend alignment rack. This from what I hear is what you need to fit our trucks up on the rack. Best up luck to you, I know I got very frustrated after trying about 9 different places.
Old Feb 7, 2007 | 04:05 PM
usdave1t's Avatar
usdave1t
OK, found one! As Jgrnaut said, it is just a case of finding somewhere with an extended alignment rack.
Thanks All!
Old Feb 7, 2007 | 04:17 PM
RedBoat's Avatar
RedBoat
Rather Be Floatin
usdave, southwest auto in Katy has a rack long enough for our trucks. cost me approx 70.00 for an alimgment. They are on Mason rd.
Old Feb 7, 2007 | 05:17 PM
BCatlin's Avatar
BCatlin
Good Luck,
Jim Henderson
I never realized that a 4 wheel alignment was required. I was always under the impression that it was only for front-wheel drive vehicles. What is the reason for the 4-wheel alignment?
While we are on the subject, how often does everyone have there's checked? The alignement seems to be staying true on my truck (tracks straight, even tire wear) and I've had it over a year. By way of comparison my Impala SS needs an alignment every 6mos.
Thanks
Old Feb 7, 2007 | 06:03 PM
krewat's Avatar
krewat
It's always good to get the thrust-line checked. Which is whether or not the front and rear axles are exactly parallel. And perfectly centered - in relation to each other.
On the odd chance that the rear (or front) axle housing is bent, you'll find out too. It can't be fixed without major surgery or replacement, but you'll find out ...
When it doesn't track straight. Or the tires wear funny. Or it wanders on the highway. You get the idea ...
That Impala, it's a newer front-wheel drive? Anything FWD from GM needs an alignment regularly. Usually...
BUT - you can get away with just a front-end alignment, just to make sure the front-end is OK.
Old Feb 7, 2007 | 06:13 PM
savage2211's Avatar
savage2211
I got mine done a sears.They did a great job.....
Old Feb 7, 2007 | 06:14 PM
BCatlin's Avatar
BCatlin
Thanks! The Impala is a 96 and I don't think the front suspension was ever designed to handle the wide 50 series tire.
Old Feb 7, 2007 | 06:17 PM
redford's Avatar
redford
When I lived on the west coast (WA) I would always take my rig to the local Les Schwab.
Don't think they have those in Houston.
Old Feb 7, 2007 | 11:17 PM
Frankenbiker's Avatar
Frankenbiker
If necessary, take your truck to a shop that does alignments on big rigs... they don't use "racks," but attach the alignment devices to your wheels while the rig is sitting on the ground.
-blaine
Old Feb 8, 2007 | 07:16 AM
usdave1t's Avatar
usdave1t
Thanks for all the info everyone! Finally got it done at Lone Star Auto (Fry Rd @ Franz for anyone in the area). Cost me $87 and they did a great job.
It was my 'toe' that was out (hence the hideous vibration at 45mph and uneven tire wear). Note that on the alignment machine it actually showed as being in the 'green' zone (supposedly OK) but it was almost on the edge of the green. The guy got it centred and it has made an amazing difference - not only is the vibration gone at 45mph but it is generally a much smoother ride.
Old Feb 8, 2007 | 09:37 AM
krewat's Avatar
krewat
Glad to hear it!
There is all sorts of leeway in alignment specs.
When you say "in the green" was this on a computer screen? Or was this a purely mechanical setting?
