clutch fluid sealed?
Old Feb 7, 2007 | 08:41 AM
91rangersupercabxlt's Avatar
91rangersupercabxlt
I have a 1991 ford ranger 4.0 5 spd. I do not have a clutch fluid resivour is it a sealed is it a sealed syestem? if so how do I add clutch fluid do i have to take the tranny out or what?
Old Feb 7, 2007 | 09:01 AM
Rangerman Stan's Avatar
Rangerman Stan
What you are saying sounds very unusual for a manual transmission truck. Have you checked the area around the firewall by the brake master cylinder for a plastic container that is light colored but partly translucent. It's about 2 inches in diameter and has a cap you can unscrew to add fluid. It has a tube coming out the bottom that goes to the clutch master cylinder there at the firewall.
Old Feb 7, 2007 | 09:55 AM
rubydist's Avatar
rubydist
It is a 'sealed' system just like the brake system is 'sealed'. The clutch master cylinder allows you to add fluid, and you bleed the system similarly to how you bleed the brake system.
Old Feb 7, 2007 | 11:01 AM
91rangersupercabxlt
I remeber checking for it before but ill look next to brake master cylinder hopfully its there
Old Feb 7, 2007 | 12:51 PM
BSmitty's Avatar
BSmitty
Find the back of the master cylinder, and follow the flexible rubber line from the top upwards to the reservoir, it should be bolted to the firewall somewhere near the base of the brake booster.
Old Feb 7, 2007 | 01:16 PM
john112deere's Avatar
john112deere
On my truck it is either bolted to the left (driver's side) fender, or to the firewall right next to the fender. Either way, right near the corner of the engine compartment.
*I don't believe it's true for any Rangers, but my father's Ford Focus uses the same reservoir for both the clutch and brakes.
awq134
2009 - 2014 F150
Dec 25, 2014 01:50 PM
adamss
May 6, 2009 12:50 PM
rsvicary
Mar 29, 2009 05:54 PM
Eric_F250
24
Mar 24, 2009 08:48 PM
