2002 alloys on a 2000?
Old Feb 7, 2007 | 08:39 AM
RangerFred's Avatar
RangerFred
Will some alloys off a 2002 ranger fit my 2000? I have 15" steels right now, but have seen some 16" alloys that would look great.
Wheels: 16x7J Bolt pattern: 5x4.5 or 5x114.3mm
Old Feb 7, 2007 | 09:57 AM
rubydist's Avatar
rubydist
No problem at all - all Ranger wheels are the same (12mm) offset and bolt pattern.
Old Feb 7, 2007 | 10:19 AM
Rangerman Stan's Avatar
Rangerman Stan
Yes the 16" alloy Ranger wheels you saw from an "02" will fit your 2000. They have the same bolt pattern. If the 16" wheels are from a 4x4 or a 2x4 Edge edition, they may be wider than your stock wheels and they may have a little different offset than yours. Having a wider wheel and different offset on a 2x4 truck could cause the tires to rub on the wheel well or the frame when making a turn or going up a curb or bump. You didn't say if your truck was a 4x4 or not. Some of these small differences can mess up the plastic fender well, or the edge of the fender or the tire. Then again, you might be able to put them on and never have any of these issues because the wheel well area is made large enough to not have problems. I know it was an issue with some of the earlier Rangers. You may just have to try it and see how it goes.
Old Feb 7, 2007 | 11:49 AM
RangerFred's Avatar
RangerFred
thanks for the info guys!
