1978 - 1996 Big Bronco
engine knocks off on right hand turns
Old Dec 10, 2002 | 09:59 PM
perryphilip's Avatar
perryphilip
in the mornings when i make sharp right hand turns, the engine hesitates for a while then continues on. what could this be?
1985 Blue and White Bronco XLT, 351HO 4bbl, C6, NP208 ,9" 3.55 limited slip, Warn Premium Hubs, Quad Front Shocks, Dual Flowmaster 50's, BFG 32x11.5 ATko's
Old Dec 10, 2002 | 10:13 PM
greystreak92's Avatar
greystreak92
Just right hand turns? I'd say idle control or excessive drag from the PS pump if it was both directions. But just to the right, you got me.
Old Dec 10, 2002 | 10:37 PM
mrwizard's Avatar
mrwizard
I might suspect a carb issue. But again, that would make more sense if it was both directions.
Old Dec 11, 2002 | 12:22 AM
Ford_Six's Avatar
Ford_Six
Your float level is probably too low. As a test, try putting it in neutral, stopping hard, and rev the engine at the same time. Probably will do the same thing.
Jared
Old Dec 11, 2002 | 11:18 AM
benz302's Avatar
benz302
I had the same problem before . It ended up being that the ignition coil was bad . The windings in the coil had vibrated loose , and when I would make a right turn the winding would short up against the can and kill the ignition system .
Took a LONG time too figure that one out .
Old Dec 11, 2002 | 09:29 PM
greystreak92
Benz302,
That had to have been a nightmare!
Old Dec 14, 2002 | 12:41 PM
perryphilip
Does anybody think it might have something to do with the fuel tank? Today, i'm going to try to hook up my timing light to the coil and tape it to my hood so i can see it, then take a few right hand turns and see if it stops when the engine hesitates. then i'll know if its an ignition problem or a fuel problem. I tried putting it in neutral, hitting the gas and stopping really fast, but it didnt do anything, so i'm assuming that the float levels are fine even though i didnt check them. Could the fuel filter be causing this? I have one, i just don't know where it goes... theres one on the carb itself, and theres one inline with the fuel line somwhere, but i've traced the fuel line, and i can't find it. thanks for your help.
Old Dec 14, 2002 | 01:19 PM
NJbronco138's Avatar
NJbronco138
