Rear Diff Gasket--question
Old Feb 6, 2007 | 03:43 PM
BigGrizz76's Avatar
BigGrizz76
Question Rear Diff Gasket--question
What up.
I got an oily-looking rear diff and I am going to replace the rear diff seal (at the same time I do the tranny pan, might as well get dirty all at once)...
my question is...
when I open up the rear pumpkin and scoop out all of the gunk...what else should I be looking for? I have no issues with the Ford 9" rear other than that wet look....but since I'll be in there anyway...
any advice would be appreciated.
peace,
Grizz
Old Feb 6, 2007 | 03:57 PM
woodbutcher05's Avatar
woodbutcher05
Hi BigGrizz76,you do realize that you will have to pull the axles out a ways to remove the center section on a 9" rear?
Leo
Old Feb 6, 2007 | 04:00 PM
BigGrizz76's Avatar
BigGrizz76
Really??? to remove the cover? I only want to replace the gasket to get it to stop leaking.
Old Feb 6, 2007 | 04:21 PM
Sport45's Avatar
Sport45
If it has a cover it's not a Ford 9". The 9" has a removable carrier and the guts come out all together from the front.
If it has a rear cover you don't need a gasket. Get the cover really clean and dry. Put a bead (1/8" to 3/16") of RTV on the face of the cover. Let it set for about 10 minutes while you're cleaning the mating flange on the housing. Install the cover and torque up in a criss-cross pattern and you're done.
Old Feb 6, 2007 | 06:21 PM
Mil1ion's Avatar
Mil1ion
Check out this site.
http://www.badshoeproductions.com/rear.html
Old Feb 6, 2007 | 06:44 PM
BigGrizz76's Avatar
BigGrizz76
thanks Mil1ion...that is a good site...
so I am 100% positive that it is a Ford 9"...there is the oily look...
I thought that I could drop the drive line, pull out the pinion and then reseal the front where it bolts to the back...but that doesn't sound right from what I am hearing...
what the ballpark to get this rear end from leaking if done by a professional?
