Sponsored by: Auxito
horrendous idle
Old Feb 6, 2007 | 09:48 AM
davek890's Avatar
davek890
horrendous idle
My 99' ford f-150 XL reg. cab, flare side (c/w 4.2L V6 and auto OD tranny) idles horribly... it started not as bad as it is now. I have to slap her into neutral and pump the throttle at stop lights to avoid stalling.
Upon firing up "the red dragon", idle tends to be fine.... an average of 2 minutes goes by before the symptoms show (sometimes the symptoms are there instantly)... JERKY idle... vroom.... vroom.... vroom... exhaust comes out in seperate puffs as the engine fires erradically. It used to be 100% once it warmed up a tad...but now it seems to be the norm. Driving down the highway at around 100km/h will result in the odd (somewhat violent) jerk of what i believe is the engine, its poor idle and border-line stall... I've read about the IAC on the forum here and believe i will start by replacing this... i will also replace the air filter, plugs and wires, fuel filter, and change out the oil and oil filter for good measure.
Anyone's input would be much appreciated here... this is a horror story since a cab ride to work costs around 40 dollars....
Old Feb 6, 2007 | 11:21 AM
KingRanchMan02's Avatar
KingRanchMan02
Hi Dave and welcome to FTE.
Does the check engine light come on? If so, get the codes checked and reply here with the diagnostic code numbers, no descriptions.
While a good tune up is not a bad idea, (for best results stick with Motorcraft parts) wholesale changing of parts most often does not fix a problem. There are lots of good people here that are willing to help.
Old Feb 6, 2007 | 11:46 AM
davek890's Avatar
davek890
Will do.
But does it sound like it could be an issue with the IAC? I will swap all the said components out anyways, since it's about due time...
Old Feb 6, 2007 | 12:46 PM
KingRanchMan02
The IAC valve can be part of your problem but it sounds like there is more to it than that alone.
kefrko
34
Dec 11, 2013 12:37 PM
Medic 66
16
Feb 17, 2007 11:35 PM
bigjeffw
1997 - 2003 F150
Feb 5, 2005 08:38 AM
bozo4ford
Electrical Systems/Wiring
Aug 13, 2003 01:31 PM
78RangerXLT
Jan 11, 2003 03:59 PM
