Here we go, let me walk you through a typical morning for cranking my 78 F150 with a 351M in it and motorcraft 2150. Get in, put gas pedal to floor and let up slowly turn the key vroom-die. pump the gas a few times crank vroom-die. pump again turn key crank vroom, sputter, truck shakes violently, 5 mins later she is smoothed out. I tried adjusting my choke and thats ok, but whats got me is my fast idle (the green screw on the pass. side of the carb) i can idle that up and the truck will run idled up when cold and thats fine and i would like it if thats all it did, but after warm up and the choke pulls off and i hit the gas to pop the idle down to low again, it doesent idle down. my friend with a '79 tbird with a 351 c cranks, runs fast, then he hits the gas and it idles down. why cant mine with a 20,000 mile 351M and new carb do the same?
Sounds like more choke adjustments to me... -They can be touchy.
When it drops off the cold idle cam the normal idle screw maintains the idle speed.
Thanks for using FTE!
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID75&conf=genconf |Garage and Shop] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID116&conf=DCConf ID9|Ranger] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID91&conf=DCConfI D12|1973-1979 Ford trucks] Forum
[link:www.ford-trucks.com/cgi-bin/dcforum/dcboard.cgi?az=list&forum=DCForumID93&conf=DCConfI D8|1997-2003 F150 and E150 Forum] [font color=red]As a Moderator I do not "Subscribe" to most topics,
please send email/pm if you need a reply -Thanks![/font]
Also check for a vacuum leak as it will cause an engine to act like crap. If the hoses are old, replace them ASAP as this is a cheap, but tedious, fix. Good luck.
