Boost guage
Old Feb 6, 2007 | 09:32 AM
redneckboy's Avatar
redneckboy
Boost guage
Drill and tap or T into the MAP line? Does it matter?
Old Feb 6, 2007 | 09:37 AM
guzzle92's Avatar
guzzle92
Depends on what type of fooler you have or plan on getting. A regulator like ITP sells - it doesn't matter as pressure remains the same throughout the map line and Y-pipe. If you get the relief valve type, it should be (a) tapped into the y-pipe, (b) use an AIH delete plug or (c) T'ed as close to the Y-pipe as you can get on the map line.
