Quick help in Denver!!
Old Feb 6, 2007 | 06:34 AM
Pocket's Avatar
Pocket
Well yesterday ripping everything out of my truck again, something goes wrong. I stripped the very last bolt on the EBPV cover that bolts up to the turbine housing on the turbo. Now I can't get it off. Is there anyone in the Denver area who can get this out for me? I'll buy you beer/lunch/whatever.
Anyone?
Old Feb 6, 2007 | 07:12 AM
DISLFVR's Avatar
DISLFVR
Locomotive breath
Hey, I know where your coming from. I 'm not in the Denver area but try this, use a Dremel tool with a cut off wheel and cut a slot on top of the bolt head for a screwdriver or a hacksaw blade to cut with, use lots of penitrating oil and let it soak a couple hours.
Old Feb 6, 2007 | 08:00 AM
Kwikkordead's Avatar
Kwikkordead
Also another trick that works well is to heat the bolt up. It will expand (lengthen) because of the heat and release it's tension at the base of the head. It will become finger tight for a couple of seconds. Take that window of opportunity to turn the bolt with a pair of pliers.
Old Feb 6, 2007 | 08:09 AM
Texas Outlaw's Avatar
Texas Outlaw
Not a liberal...
Or you can cut the head of the bolt off, remove the part that it is bolted to and then remove the stud. We do that a lot with well caps at work and it works well.
Old Feb 6, 2007 | 01:40 PM
Pocket's Avatar
Pocket
The only problem is at the moment I'm very limited on hand tools. So I basically have nothing to cut with or heat. The only cutting tools I have are way too large for this job.
Anyway, it looks like I may be able to take it to someone local and have them extract the bolt for me.
Now if I don't screw up anything else, I'll be ok.
