1978 - 1996 Big Bronco
TPS Adjustment
Old Dec 18, 2002 | 07:11 AM
fcarruth's Avatar
fcarruth
TPS Adjustment
I replaced my TPS a couple of weeks ago and just read on a POST that it needs to be adjusted between .95V and .99V when hot and 4V at WOT. What is the best way to adjust it and what is WOT ? Chilton, Haynes and Mitchell don't really tell you anything other than it needs to be adjusted. I have a new TB gasket so it wouldn't be hard to take it off and put it back on a few times since it's not brittle yet.
Thanks for the help and Happy Holidays to All ! :-X12
Old Dec 18, 2002 | 07:39 AM
steve83's Avatar
steve83
TPS Adjustment
Wide Open Throttle
Later ones aren't adjustable, but I think your '89 uses the kind with slotted screw holes. Just loosen the screws and turn the TPS slightly while monitoring the voltage on a meter. Haynes gives the pinout & procedure.
Old Dec 18, 2002 | 04:43 PM
Steve0's Avatar
Steve0
TPS Adjustment
For the older ones you can take a dremel tool and slot the screw holes for adjustment.
Steve
Old Dec 18, 2002 | 06:14 PM
NJbronco138's Avatar
NJbronco138
TPS Adjustment
would you have to adjust the TPS sensor on a 91 or is it preset?
Old Dec 18, 2002 | 06:48 PM
Flash's Avatar
Flash
TPS Adjustment
My 91 EB,302 does not have an adjustment.
Old Dec 18, 2002 | 07:05 PM
NJbronco138
TPS Adjustment
So it should be the same on a 351W?
Old Dec 19, 2002 | 06:45 AM
gregdatech2's Avatar
gregdatech2
TPS Adjustment
If the TPS has slots on it, then its adjustable. If it doesnt, it isnt. In the case of a non-adjustable TPS, if it reads out of spec at idle and wot, then its bad, and needs to be replaced. No sense in dremeling it, since theres something wrong internally. Certain years were adjustable, usually in older models. If the 5.0l truck was adjustable, more then likely, the 5.8l will be too.
Old Dec 19, 2002 | 02:06 PM
spixican07's Avatar
spixican07
TPS Adjustment
rterril02
Apr 17, 2016 06:15 PM
LSO1123
Dec 22, 2015 01:29 AM
Chefsteele
168
Dec 18, 2013 10:29 PM
Forddiesel17
Dec 4, 2013 04:27 PM
Jrock909
Jul 29, 2006 02:00 PM
