Thought i has a posi......
Old Feb 5, 2007 | 12:49 PM
Dans4X4F150's Avatar
Dans4X4F150
Thought i has a LSD......
but just pulled the cover and i see spider gears, not a posi!. 98 XLT F150 4x4 with towing package WTF! If i do a burnout both tire spin and it kicks out sideways! Both tire spin if i do a donuts LOL So oh well
Old Feb 5, 2007 | 01:01 PM
Dans4X4F150
Thought i had a LSD :(
sucks
https://www.ford-trucks.com/forums/5...as-a-posi.html
Old Feb 5, 2007 | 01:39 PM
Steina's Avatar
Steina
CO River Rat
If you can light up both rear tires during your burnouts/donuts, then you've got a limited slip differential (WTF). Also, if you do these tricks a lot, you might be overheating your gear oil which could force it out the vent.
Steve
Old Feb 5, 2007 | 02:03 PM
Dans4X4F150
just looked up the rear end codes and its a 355 lsd
Old Feb 5, 2007 | 02:40 PM
LSUtigers's Avatar
LSUtigers
did i miss something here>?
Old Feb 5, 2007 | 02:45 PM
Dans4X4F150
did you click the link??
Old Feb 5, 2007 | 02:47 PM
scottie2hottie's Avatar
scottie2hottie
I thought you saw spider gears when you pulled the rear end cover?
Old Feb 5, 2007 | 02:50 PM
Dans4X4F150
yeah i did se spider gears! WFT lol both tires always spin thoe and the Door code is sat 3.55 LSD. 98 5.4 XLT 4x4 off road F150!
Old Feb 5, 2007 | 03:30 PM
LSUtigers's Avatar
LSUtigers
yah, saw that you have LSD...and?
Old Feb 5, 2007 | 04:11 PM
jimm66's Avatar
jimm66
????????????????????????????????????????????huh
Old Feb 5, 2007 | 06:13 PM
mhg's Avatar
mhg
lsd still have the spiders
they also have clutch packs on the
axle side of the spiders
Old Feb 5, 2007 | 07:08 PM
Dustin1690's Avatar
Dustin1690
KK check your axle code unless somone already blew up that rear end and swapped it out if its H9 its a 3.55 LS but if it s 19 its like mine 3.55 Non LS thats just an example REMEMBER #and letter= LS numbers= non LS unless its been swapped out...
Old Feb 5, 2007 | 07:21 PM
Dans4X4F150
yes it says H9
Old Feb 5, 2007 | 07:22 PM
Dans4X4F150
kool thanks
Old Feb 5, 2007 | 11:54 PM
Torque1st's Avatar
Torque1st
Posting Legend
Threads merged.
