1966 - 1977 Early Broncos
hard pedlel
Old Feb 5, 2007 | 09:08 AM
4drf350's Avatar
4drf350
hard pedlel
Hello everyone I have a 1967 bronco I have put a 302 in it an power steering an I have put a hydoboost brake on an it worked great for a while but now my brakes are hard to push an the pedel hardly moves I still have drum brakes on it for now . Also I am wondering if the gears in my dana 30 will fit into a dana 44 I want to put undre my bronco I am going to rebuild it this week my bronco has 4.10's the 44 has 3.50's can I swap them . Thank you Rick
Old Feb 5, 2007 | 10:06 AM
RCrawler's Avatar
RCrawler
Are you getting any flow from the power steering pump to the hydroboost unit? Do you have any way to test pressure? Is your steering working normally? Does it stop with the hard pedal?
The ring and pinion or the carrier will not interchange between a Dana 30 and a Dana 44.
Jason
Old Feb 5, 2007 | 10:13 AM
4drf350's Avatar
4drf350
Yes it will stop it lock them up. I did bleed them again an that did not fix anything I will check for to see if I have flow .The way I have it plumb is it come off the power steering pump an gos to the hydroboost then to the steer box .
Thank you fo the info on the dana axles . Rick
Old Feb 11, 2007 | 10:03 PM
walker949's Avatar
walker949
your getting back pressure in the system. Did you use a dual return pump of the TEE setup?? If you have the TEE, it is plumbed incorrectly causing this.. if you have a dual return something in your system is blocking the flow, start checking around
Old Feb 12, 2007 | 08:25 AM
4drf350's Avatar
4drf350
I have a tee set up. what is the right way to plumb it or should O get a duel return pump . Rick
Old Feb 13, 2007 | 05:50 AM
ken75ranger's Avatar
ken75ranger
The tee should be set up with the return line from the steering box straight through the tee to the pump. The hydro-booster in the 90 degree spot. Connect it as close to the pump as you can.
Old Feb 13, 2007 | 08:29 AM
4drf350's Avatar
4drf350
Thank you I will try that . Rick
Radster
Dec 5, 2016 01:20 PM
Big_Red_Brute
Jan 24, 2016 07:45 PM
obx 79 shortbed
Aug 30, 2014 10:20 AM
nonrev321
Sep 8, 2012 01:37 PM
Elvis40
Feb 14, 2012 08:19 PM
