F-350 Master Cylinder Swap on F-150
I want to do the F-350 brake booster swap on my 1990 F-150. I understand the swap itself is not hard to do, but I want to know if I need to change anything else?
I am also planning on doing an Explorer rear disc brake conversion. I assume this will work with the F-350 brake booster?
In the front I have a Dana 44 straight axle from a '79 Ford F-150. I still have the stock calipers on it for now, but I was wondering what the difference is between those and the calipers for a Dana 44HD? Since the HD was a 3/4 ton axle, I assume the brakes might be bigger, but I don't know for sure.
Any help is appreciated!
moodybo
03-18-2009 12:55 AM
sum_weirdo
06-24-2008 12:31 PM
kettle-one
20
09-23-2006 06:43 PM
