Sponsored by: Innova
XM Power Source
Old Feb 4, 2007 | 10:15 PM
Medic 66's Avatar
Medic 66
XM Power Source
I have attempted to use a fuse tap to direct power my XM XRC-9 AudioVox setup so that I can free up the cigarette lighter port. However, after a minute or two the unit just keeps recycling on and off like it is not getting enough power and resetting itself and trying agian.
How else may I go about getting a direct power source?
Thanks,
RC
Old Feb 4, 2007 | 10:32 PM
SPL Tech's Avatar
SPL Tech
That is because the XM cigarette lighter plugs have a built in transformer in them. They convert 12VDC to 6VDC. You are running double the rated voltage to that tuner without the transformer. I am amazed it still works. Dont attempt to turn it on again without the transformer. You need the transformer inside the cigarette lighter plug. You can open the casing and solder wires directly to the transformer if you would like. That’s what I do with every one of my XM installs.
Old Feb 5, 2007 | 05:33 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
...or just solder in a resister in line to drop voltage down to 6 volts. Use a 3 or 5 watt resister, tape well and hide wiring.
Old Feb 5, 2007 | 10:31 PM
SPL Tech's Avatar
SPL Tech
Yes. But if he knew ohms law and knew what value of resistor would be required to drop the voltage to an appropriate level, I think its safe to assume he would also have noticed the plug has a transformer in it.
Old Feb 9, 2007 | 08:41 AM
fordboy_52's Avatar
fordboy_52
i would use the transformer. if you use a resistor you can also change the current and you still might smoke your xm unit
Matt
Old Feb 9, 2007 | 11:08 AM
mattyk6_bdr's Avatar
mattyk6_bdr
A lot of people just tap in a new cig lighter adapter and plug the sat radio power cord into that.
