Sponsored by: Real Truck
Heater Blower moter
Old Feb 4, 2007 | 03:59 PM
velnof's Avatar
velnof
Heater Blower moter
Just noticed this last week that my heater blower moter is not working on all the settings. The speed kicks up on the second dot setting and the third dot setting is the same as the second. The fourth dot setting high, works like it always has. My question is where should I start looking to fix this problem? In the Relay with the fuses, or might it be the fan switch in the dash?
Thanks for your help.
Old Feb 4, 2007 | 04:11 PM
BowTieHatr's Avatar
BowTieHatr
do you have ***** or a eatc head?
Old Feb 4, 2007 | 04:22 PM
velnof's Avatar
velnof
I have the *****.
Old Feb 4, 2007 | 04:39 PM
BowTieHatr's Avatar
BowTieHatr
check you blower resistor. it is behind the accumulator under the hood.
Old Feb 5, 2007 | 05:31 AM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
Moved to SD.
Old Feb 7, 2007 | 06:09 PM
velnof's Avatar
velnof
OK I looked and couldn't see anything that I thought might be the resistor.
What might I be looking for? size/color I thought it would be easy to find, but no such luck for me.
Old Feb 7, 2007 | 09:02 PM
BowTieHatr's Avatar
BowTieHatr
it will be a one inch square connector to the drivers side of the blower motor behing the accumulator. it should be a gray connector with 5 or 6 wires around 10 or 12 gauge.
riattadog
Oct 12, 2014 07:58 PM
pjsbronco
Aug 29, 2011 01:01 PM
ford0625
Jan 4, 2010 12:02 PM
Kitty71
Aerostar
15
Dec 18, 2006 09:09 AM
D1newbie
Electrical Systems/Wiring
Oct 28, 2003 02:19 PM
