Tail Light Wiring
Old Feb 4, 2007 | 02:58 PM
Ronindog's Avatar
Ronindog
Tail Light Wiring
Good day to one and all.
Some of you may recall my "epic journey" recently to correct my 66 slick brake light, turn signal and running light issues.
One of the remaining problems is that the smaller of the two filaments in the bulb lights as appossed to the larger filament, when the brakes are applied.
Someone indicated that the fix is a realitively easy one.
Suggestions, directions on how to correct this would be greatly appreciated.
Have a good one
ronindog
Old Feb 4, 2007 | 03:18 PM
butch h's Avatar
butch h
The shorter filament is the higher candlepower (brighter).
Old Feb 4, 2007 | 04:57 PM
Franklin2's Avatar
Franklin2
There should be 3 wires to the socket. Two hot wires and a ground. Just swap the hot wires.
Old Feb 4, 2007 | 05:22 PM
Ronindog's Avatar
Ronindog
Butch, someone previously said the larger was the brighter. Was that incorrect?
and
Dave, appreciate the suggestion however there are only two wires. the unit grounds to the frame.
i've tried the "switch the wires" in the past to no success, but i'll give it a try again
thanks
Old Feb 4, 2007 | 07:10 PM
butch h's Avatar
butch h
If you put twelve volts to the brass,or cylindrical part of dual element lightbulb,you can readily tell which is the brighter.On the 1157 lightbulb,the shorter filament is the brighter (stop/turn),and the taller is taillight.
Old Feb 4, 2007 | 08:15 PM
Franklin2's Avatar
Franklin2
If swapping the wires does not work, you have a socket problem/wrong socket. The bulb should be the 1157. Make sure it is.
If you get someone to hold the brakes, one of the wires should be hot. Touch it to one of the socket wires and one of the filaments should light. Touch it to the other wire and the other filament should light.
Old Feb 5, 2007 | 10:40 AM
butch h's Avatar
butch h
I inadvertently left out that you put the other lead of your twelve volt source to each of the "lugs" on the bulb to determine the brightest, sorry for any confusion.
08KR
2004 - 2008 F150
Sep 7, 2016 11:36 AM
usaf2012
Jul 4, 2016 03:34 PM
abe
Jun 24, 2016 10:12 PM
Shadowrider123
18
Dec 24, 2014 08:14 PM
SocialDistortionFan
Jul 9, 2013 11:25 AM
