Trans wont seporate
Old Feb 4, 2007 | 02:17 PM
94f1504.9's Avatar
94f1504.9
Trans wont seporate
I got the transmission supported by a trans jack and have the starter, inspection plate bolts, and 6 transmission bolts removed. The crossmember is also removed and the transmission wont come free of the engine. Any ideas?
Old Feb 4, 2007 | 04:47 PM
bohiaa's Avatar
bohiaa
Is this a standard ?
Old Feb 4, 2007 | 04:48 PM
MustangGT221's Avatar
MustangGT221
Automatic or manual?
You'll probably have to pry it off and make sure you angle it properly...if you don't try and take it off straight you won't get it off.
Old Feb 4, 2007 | 04:50 PM
ubereal2's Avatar
ubereal2
Automatic or standard?
Do you have the driveshaft dropped down, transmission mounts and brackets out? You are most likely going to have to pry them apart.
Old Feb 4, 2007 | 07:33 PM
jroehl's Avatar
jroehl
Do you have the torque converter unbolted from the flywheel (if A/T)? Should be 4 nuts.
Jason
