Sponsored by: Real Truck
Lift Kit Height?
Old Feb 4, 2007 | 11:36 AM
sas701's Avatar
sas701
Lift Kit Height?
I have a '99 F250 4x4 7.3L CC which I purchased used from a local Ford dealer. The truck came with a lift kit already installed and BFG 315-70R-17 ATs. I am looking to upgrade my shocks to smooth out the ride somewhat. Anyone have any suggestions on how to determine the height of the lift kit? I think it is probably 4" or 6" but I want to make sure before I spend a couple hundred bucks on new shocks.
Any recommendations on shocks? I tow a 38' toy box. The truck has a dual shock set-up in the front and Firestone Ride Rite air bags on the rear.
Thanks - Scott
Old Feb 4, 2007 | 12:59 PM
ProAuctioneer's Avatar
ProAuctioneer
Scott,
can you see who the manufacturer of the lift is? It may be stamped or painted on a component of the lift along with a possible part number that you can reference to when you contact the manufacturer of the lift.
Old Feb 4, 2007 | 01:56 PM
sas701's Avatar
sas701
I can't find any manufacturer id on any of the suspension components. Only thing I could find is the shocks currently on there are Explorer 32650 (front) and Explorer 33200 (rear). Tried "Googling" that but came up with nothing.
Thanks,
Scott
Old Feb 4, 2007 | 10:28 PM
joe_jeep's Avatar
joe_jeep
explorer should be pro comp aint it?? remove a shock there will be small numbers in the shell of the shock body. your parts guy or off road shop can decipher the numbers.
also can measure compressed length and extended length for a correct measurement.
Old Feb 5, 2007 | 01:22 AM
spunks00's Avatar
spunks00
from my understandings you can only run up to 4in lift w/ airbags in rear, but that dont seam right, but i have herd it...who knows...
try measuring the rear block, stock should be 2in so a
2in leveling kit would have a 4in block,
a 4in kit would have a 6in block
6in lift would have a 8in block or a 6in block w/ add-a-leaf
that is of course if you have stock springs,
how safe is a 8in block anyways
hope that helps
Old Feb 5, 2007 | 08:53 AM
sas701's Avatar
sas701
I have a 4" block on the rear in addition to the stock 2".
Old Feb 5, 2007 | 10:29 AM
chuck641's Avatar
chuck641
You probably have a 6" lift then. With a 4" lift the back is usually only raised about 2.5", since yours is raised 4" it is probably a 6" lift.
Old Feb 5, 2007 | 10:54 AM
bbender85's Avatar
bbender85
^ my thoughts exactly.
Old Feb 10, 2007 | 06:52 PM
DCSpecial's Avatar
DCSpecial
You can measure between these two points on the passenger side of the front axle:
From the top of the axle tube (next to the spring perch) to the bottom of the frame rail (next to the bumpstop).
A 4" lift will place you ~11.5-12"
A 6" lift will place you at ~13.5-14"
Either way, I'd recommend Donahoe Racing Signature Series Shocks.
Old Feb 12, 2007 | 03:38 PM
sas701's Avatar
sas701
I came up with 12.5" so where does that put me?
I already purchased the Bilstein 5100 shocks, which should be delivered today, because they had one model which covered F250s lifted 4"-6". Hopefully I'll be OK with these.
Old Feb 12, 2007 | 05:17 PM
DCSpecial's Avatar
DCSpecial
4-5" lift with that measurement.
Souz7.3
Mar 29, 2016 02:26 PM
rally68
Mar 26, 2016 12:35 AM
jamesbfishin
Sep 16, 2015 09:12 AM
tennesseex
Sep 4, 2015 08:36 AM
mgfranz
Jan 23, 2013 11:59 AM
