ATS Turbo
I'm new to diesels and I'm in the process of changing my glow plugs on my new to me 93 f250.
One of the plugs is directly underneath the turbo that the previous owner installed. I have no installation or removal manuals for the turbo so I'm wanting to know which is the best way to remove the turbo. Some of the bolts in the back seems imposible to get to. I looked underneath and seen some connections for the manifolds. Do you guys disconnect the pipes from the bottom and pull the turbo out with the pipes or do you disconnect everything from the top?
If anybody got any diagrams manuals or info on these turbo's I sure would like to see. I e-mailed ATS a couple of times but all I got was silence.
Thanks
Although it is a real pain to do, I have changed it without removing the heat shield.
That glow plug takes longer to change than all the rest put together.
Spectramac I have other reasons for taking that turbo off besides the gp. I have a bad oil leak somewhere back there and maybe the drain for the turbo might be the culprit. But I would still like to know the best ways to remove it. Any tricks too making the job easier is always helpful.
also removing the turbo wasnt really bad, just a pain. Spray the fitting at the up pipe (cast Y) let it sit while you are removing the other pipes and top end parts (air cleaner and oil line) keep the turbo solid at this point. Remove the Y casting bolts and drive the flange with tap tool (4 pounder recommended). Now go back up and remove the turbo mounting nuts and remove the turbo. You might find the o ring has failed or the previous installer didnt make a drain hole in the lower valley pan.
also are you sure its motor oil and not fuel ?? I havent seen the oil drain o ring fail unless it was pinched during installation.
