1959 F-100 rear axle id
Check the rating plate on the inside of the glove box door and then look for the numeric code for the axle This code will tell you what ratio you have. It will be a 3.70/code 01 or 3.89/code 02 or 4.11/code 03 ratio.
If the axle is a 9 inch Ford--you have an open differential. If the axle is a Spicer 44--then it has the factory limited slip differential.
Choptopjimmy
08-02-2013 01:47 PM
-Mike-
12-03-2006 07:38 PM
sd59f100
15
02-24-2006 03:55 PM
