Starting Problem - Fuel Related
Old Oct 13, 2007 | 12:23 PM
AutoHound's Avatar
AutoHound
Hello! I have a 1990 Ford F150 with the straight six. When I want to start the engine I have to pause at the "on" position with the switch until I hear the fuel system charge up, then engage the starter. This usually produces a reasonably good start, but sometimes I have to "recharge" the fuel system to get a good start. The truck has done this for quite a while and is not dependent on which tank I'm on. It runs like a top after starting.
Thanks for any guidance!
Old Oct 13, 2007 | 12:54 PM
flareside_thunder's Avatar
flareside_thunder
Could possibly be the fuel filter needs changed or somehow the systemis losing it's prime through a slight leak....
Old Oct 13, 2007 | 12:58 PM
AutoHound's Avatar
AutoHound
Thanks, flareside_thunder! I changed the filter when it started doing this and it didn't help. I think you're probably on to something with the leak theory, but I've always thought that I should be able to see fuel leaking somewhere! Maybe not? Are there certain connections that I should try to tighten?
Old Oct 13, 2007 | 01:38 PM
subford's Avatar
subford
No the fuel leak would be the Fuel Delivery Modules hi-pressure check valves leaking back to the tanks or the fuel injectors leaking into the intake manifold.
Old Oct 13, 2007 | 01:52 PM
AutoHound's Avatar
AutoHound
Thanks, subford, that makes sense! So, not much I can do about it except to start replacing components?
