04 bed jiggle?
Old Feb 2, 2007 | 07:00 PM
c ball's Avatar
c ball
04 bed jiggle?
I know its been talked about here but I still didn't hear what caused the beds on the 04 supercrews to jiggle up and down on rough roads?Also I have a rattle in the back seat near the back window and cant find it .Any help will be apprepiated ,thanks
Old Feb 2, 2007 | 09:52 PM
Dustin1690's Avatar
Dustin1690
I think it was bed bushings i maybe wrong but i would do a search on this to find out or go to your dealer they might know....
Old Feb 2, 2007 | 10:16 PM
the4by4freek's Avatar
the4by4freek
Don't worry about it. It is normal. As far as your rattle... they are quite a PITA to locate. Do you by any chance have a sunroof? If so, then it is your headliner. Do a search for headliner rattle and you'll have your fix.
Old Feb 3, 2007 | 09:05 PM
rambunctious's Avatar
rambunctious
check the plastic cover over the seatbelt bolt at the top
mine was undone and the rattle drove me nuts til i found it
it is a living hinge part, just snap it on, if that's the cause.
I got used to my 04 bed shake, till this winter. seems to be agravated by colder temp ( harder tres? softer tires? ) but is quite anoying.
there was a TSB to add a dampened mass that can be bolted onto the left rear end of the frame. I may look into one. it's really bugging me lately
Ramb
Old Feb 4, 2007 | 06:30 PM
c ball's Avatar
c ball
Thanks, I guess I can live with the bed shake ,but that rattle is annoying..
Old Feb 4, 2007 | 07:56 PM
smokestone52's Avatar
smokestone52
I have the 06, similar truck. My bed shakes like crazy on rocky dirt roads. And I have the annoying cliking sound. I know what mine is, I have the power slider rear window. There is a TSB out on this from Ford. I just haven't taken mine in yet. Ain't nothing like an annoying rattle, click or what ever it is, to drive ya nuts. Other than that, these big Fords rock!
Old Feb 4, 2007 | 09:45 PM
96f150's Avatar
96f150
I think tthe bed shakes are due to the shocks being mounted on the outside of the frame rail. This will pick up any differences in the road and magnify them.
Old Feb 5, 2007 | 07:18 PM
Ferguson65's Avatar
Ferguson65
I'd lean more toward the fully boxed frame for the bed issue. Unfortunately, strength has it's weaknesses, like the much less forgiving ride. On rough roads mine will bounce all over, the frame has very little flex to it. It's the price you pay for a half ton thats really not a half ton.
Old Feb 5, 2007 | 07:45 PM
the4by4freek
I'm with ya Ferguson.... I'll give up a little bounce for payload and towing capacity
Old Feb 6, 2007 | 07:07 AM
joeypurcell's Avatar
joeypurcell
Every truck I follow has the bed shaking over any surface other than smooth roads. It is not just our trucks. After adding a bed cover that mounts inside the rails, my bed shake is almost completely gone, but heavy bumps will bring a little shake. As far as the rattle, I am still trying to hunt mine down, I have stripped the entire back seats out, and still nothing. My wife has figured out it is coming from the back portion of the backseat (so she thinks) Mine may be inside the seat cushions, who knows. If I evev find mine, I will make a post on it.
Old Feb 15, 2007 | 07:02 PM
baitmaster's Avatar
baitmaster
My '05 150 has a rattle on the pass side door area when on rough roads. It sounds like the suicide door is the culprit, but havent really looked into it. I've noticed when watching one of those Chevy or Nissan/Toyota ads on TV, if you look close, you can see their bed jumping around too. I'm hoping the new Rancho's will help a little. My old '72 always road a little better with a few hundred pounds in the bed, maybe I should throw a few old Chev parts back there?
Old Feb 15, 2007 | 08:51 PM
bpez's Avatar
bpez
I heard people complaining about the wiring for the rear sliding window. It likes to sway back and forth against the back wall.
Old Feb 16, 2007 | 06:14 PM
baitmaster's Avatar
baitmaster
I have a looped strap coming out of the interior trim just below the center of the rear slider. Anyone have an idea what this is for? I have pulled on it, but didnt get crazy.
Old Feb 16, 2007 | 07:24 PM
the4by4freek
That is an anchor point for a child seat. You have 3 of them in the back seat.
Old Feb 16, 2007 | 09:12 PM
Simmy150's Avatar
Simmy150
The bed flex is not an issue.
My rattle was caused by too little gasket around the power sliding rear window. It's pretty common on these. Take it to the dealer.
alandg46
1983 - 2012 Ranger & B-Series
Feb 7, 2013 05:04 AM
lattices2
1978 - 1996 Big Bronco
Nov 19, 2005 08:10 PM
GeneStoner
May 14, 2005 11:36 PM
htf
Sep 20, 2004 12:37 PM
DS02F250
Jan 30, 2004 03:17 PM
