1978 - 1996 Big Bronco
speedometer "jiggles"
Old Nov 17, 2005 | 06:15 AM
lattices2's Avatar
lattices2
'90 351W EFI (just passed 160,000 miles)
Just read a speed sensor post so thought id post new rather than continue.
As i accelerate or decellerate, my speedometer "jiggles" back and forth a little as it goes up or down.
I dont know if its always done this or if id just started paying attention. I think i would have noticed it before. Ive had the truck 4 years
Is this a possible speed sensor problem or just ignore it?.
Thanks
Old Nov 17, 2005 | 08:18 AM
jmalecek's Avatar
jmalecek
If it's a '90 your speedo is cable driven. Sounds like the cable needs to be replaced.
Old Nov 17, 2005 | 08:42 AM
lattices2's Avatar
lattices2
'90 351W EFI
If thats the case Ill ignore it for now. I assume it has no inputs to the computer and is just a mechanical thing.
Old Nov 17, 2005 | 03:48 PM
greystreak92's Avatar
greystreak92
Yep, Ford didn't switch to the PSOM setup until 1992. From 92 on the speedo and the odometer were fed information via the VSS which also sent the same info to the computer for shift functions and cruise control monitoring.
Old Nov 18, 2005 | 05:36 PM
thenewjohndeere's Avatar
thenewjohndeere
My '91 does the same thing ... i took it out and regressed it once and it smoothed out, but a yr later its back to were it was ... i think that mabey the chain/wire that runs from the speedometer to the sensor is just starting to catch on the plastic sleev its in (almost like the wires in the chain have developed some breaks in it). I'm no mechanic and i'd take this as just an idea, but i figured i'd give my 2 cents.
Does yours do it more when its cold? I know its winter when i drive to the end of the street (800ft) and it says that im going 75mph.
I think its the chain but im too cheap to drop money on it. Actually i looked at the advanced page and there like 20 bucks, i could have sworn that it was 50 last time i looked ... might go get one this weekend.
(i guess you know your done with your post when you talk to yourself on it)
Old Nov 18, 2005 | 09:11 PM
Tim Halliday's Avatar
Tim Halliday
I had a similar problem with my '91 a while ago. I lubed the cable, but it didn't help. It turned out that there was a piece of dirt in the pivot point of the spedometer needle. The needle would go up just fine, but got stuck coming down.
A little spray silicone lube and never had a problem since.
Old Nov 19, 2005 | 12:40 PM
lattices2's Avatar
lattices2
thanks for the info. Where is this cable where i can access it? Since its now snowing and cold i need to spend as little time as possible under my truck.
Old Nov 19, 2005 | 08:10 PM
greystreak92
It runs from the back of the speedometer down through the truck to the tailpiece on the transmission. Some applications had the cable output in the transfer case but I can't recall which tranny/t-case setup it was now.
Paul Bostic
2004 - 2008 F150
Feb 7, 2017 07:54 PM
88_F0RD
15
Dec 4, 2016 12:45 PM
abs777
Oct 5, 2016 04:24 PM
Higgin
1983 - 2012 Ranger & B-Series
16
Dec 1, 2004 04:13 PM
