glow plugs not working
Old Feb 2, 2007 | 02:19 PM
shanesdad's Avatar
shanesdad
Question glow plugs not working
Hello. Has anyone heard of all the glow plugs not working due to a bad connection in the main plug which name escapes me. Anyway, I had a mechanic in south dakota cross the gp relay and tell me that it is 95% of the time the wire in the big multi wire plug isnt making contact. He said to "pull it out and flatten it a little and it will work. Everyone else will tell you to replace the whole assembly." OK, where is that plug and by the way it was a gray wire. He had an old harness and showed me.
Old Feb 2, 2007 | 06:09 PM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
Sorry - but we need more specific info. Vehicle, year, engine, transmission, etc.
Old Feb 2, 2007 | 06:26 PM
trike1946's Avatar
trike1946
Welcome to FTE. A little more info would help us help you. If it is the F-350, you might get more answers in the 99-2003 PSD forum down the page a bit.
Old Feb 3, 2007 | 02:47 AM
shanesdad's Avatar
shanesdad
2002 f350 4x4 auto, deisel (duh...) I wish I could think of the name of the wiring harness plug thing...But I cant... help...
Old Feb 7, 2007 | 07:33 PM
bigredtruckmi
Veteran: Navy
Lets see if we can get this one moved.
Old Feb 7, 2007 | 08:36 PM
Kwikkordead's Avatar
Kwikkordead
Welcome to FTE.
If you have a glow plug relay, it's mounted on the top of the engine.
I don't know much about the 2003's but some of them have a glow plug module instead of a glow plug relay which makes it a whole different animal.
Old Feb 7, 2007 | 09:04 PM
guzzle92's Avatar
guzzle92
The PCM is what gives the GPR the ground connection to activate. He must be referring to the multi-pin plug that connects the GPR to the PCM. I suppose a faulty or loose connection here could keep the GPR from closing but most of the GPR problems we find here are due to a voltage drop across the contacts caused by arcing and age.
Old Feb 10, 2007 | 12:53 PM
shanesdad's Avatar
shanesdad
pcm,bingo!!
Thats it. The pcm multi pin plug. A mechanic showed me one from his bench and said the wires sometimes corrode or otherwise lose good contact. Most places replace the multi plug at considerable expense when it may be rectified much easier. OK, next question , where is it and can any damage be done by unplugging it and checking it out? He also showed me the wire it is which is the grey one. By the way, it is an 02, not 03. Thannks to all, what a great source of knowledge to be able to tap into...
Old Feb 10, 2007 | 12:55 PM
shanesdad's Avatar
shanesdad
one more thing
He also ran a wire from the gpr to the battery ground and determined that the gpr was ok. That make sense???
Old Feb 10, 2007 | 05:10 PM
PA_Ford_Man's Avatar
PA_Ford_Man
Yes, that would make sense. All he did was provide a ground path for the GPR to activate. It would have been the same as the PCM would have done. The PCM provides the ground connection for the relay coil, which causes the relay contacts to close, providing high current 12V to continue down to the Glow Plugs.
Old Feb 10, 2007 | 06:31 PM
shanesdad's Avatar
shanesdad
So, very possible it is the connection in the pcm and not the relay? Now all I haveto do is find the pcm multi plug and check it out.. Thanks... u got the same ride only I have the crew, 4" exhaust and soon to have the 6637. Any advice on that??
Old Feb 10, 2007 | 06:33 PM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
Its very unlikely that it is the PCM plug, if it happens to be the problem, it will be the first i've heard of it. The PCM connector harness is located on the driver's side of the firewall, the PCM is actually inside the cab but the connector is on the outside. Right below the brake master cylinder you will find a connector, remove(loosen, it wont come out all the way) the 10mm bolt and wiggle off the connector. good luck.
Old Mar 24, 2007 | 11:49 PM
shanesdad's Avatar
shanesdad
need some help. 02 f350 4x4 80k mileage. just noticed a small drip of oil on the ground. not coming off the pan. comingfrom the smaller pan located behind the main pan. also noticed some on the intake manifold. any ideas on what. it is very black and even after a fresh oil change. help...
shanesdad's Avatar
shanesdad
forgot, diesel as well
Old Mar 25, 2007 | 01:26 AM
Tenn01PSD350's Avatar
Tenn01PSD350
Shanesdad, although it is your post and you can hijack it all you want, you will get better results starting a new thread specific to your problem.
Ok, there are several possible sources of your leak. It could be fuel mixing with grime on the engine valley making it look black, or it will be oil. Both will pool in the valley and drain down the back via a hole and appear near the tranny inspection cover behind the pan. Your first step is an inspection of the fuel bowl and lines as well as the HPOP and lines to the heads. Also, if it is pooling in the back only look at the turbo pedestal for possible oring failure there. At any rate, a good cleaning/degreasing will help pinpoint the leak which I believe you will find up top.
catbird7
Nov 16, 2011 04:41 PM
galute
Nov 6, 2010 11:32 AM
muddingmcdude
34
Mar 15, 2010 10:22 AM
Feepaholic
Oct 24, 2009 04:32 PM
huntharbor
16
May 1, 2007 01:31 PM
