02 sensor replacement
Old Feb 2, 2007 | 12:49 PM
rsylvstr's Avatar
rsylvstr
My mechanic (my best friend's dad) says that sometimes the heated O2 sensors should be replaced before they go bad and start spitting codes.
anyone bother doing this?
if so, which ones, or did you replace all?
MC brand?
Old Feb 2, 2007 | 08:57 PM
ubereal2's Avatar
ubereal2
Smile
When would that be???
I also have an 01 with almost 120K, have never had to replace more than the DPFE sensor.
If it ain't broke.. Don't fix it. But I keep my maintenence up to the letter.
Bob
Old Feb 2, 2007 | 10:18 PM
ReAX's Avatar
ReAX
O2's should be replaced at 60K miles, they can last longer. However your performance and mileage will suffer once they begin to fail. I use motorcraft now, they plug into the stock harness. I have tried some aftermarket that required splicing.
Old Feb 2, 2007 | 10:21 PM
ReAX's Avatar
ReAX
I forgot F150 have four, the post cat sensors monitor only the emissions aspect. The pre-cats talk to the ecm for engine management. You can replace the fronts and wait for the rears to fail, but it would be easier to replace them at once so you know how old they all are.
Old Feb 3, 2007 | 09:55 AM
rsylvstr's Avatar
rsylvstr
are all four the same part?
any sponsors have good prices?
Old Feb 3, 2007 | 10:47 AM
ReAX's Avatar
ReAX
DY-1039 5C5Z9F472AA XC2F-9F472AA Front
DY-1093 F85Z9G444BA F75F-9G444BA F85F-9G444BA Rear
So no, front and rear have different pns.
Old Feb 3, 2007 | 11:48 AM
rsylvstr's Avatar
rsylvstr
Thanks ReAX....let's hope i don't have a problem getting them out...my 92 Galant is seized and i can't break her loose, even with a breaker bar and penetrant....rather just leave that one in there!
Old Feb 3, 2007 | 01:32 PM
galaxie641's Avatar
galaxie641
I've found if you run the vehicle so the exhaust gets warm they can be easier to remove, also helps to spray them down with Pb blaster a few days before you plan on removing them. I try to replace mine every 60-80K, rears are $5-$10 more than fronts IIRC.
Old Feb 3, 2007 | 03:07 PM
rsylvstr's Avatar
rsylvstr
another member said the same thing, i've blasted it twice and tried once warm and once HOT....no joy.
therigwelder
42
Dec 19, 2015 09:02 PM
gccch
2004 - 2008 F150
Aug 25, 2014 12:50 PM
Pyancey
Jan 16, 2013 09:08 PM
aocabrown
Dec 28, 2007 11:08 PM
irishguyincc
1983 - 2012 Ranger & B-Series
19
Nov 12, 2005 08:56 AM
