Diesel Trigger = Officially PULLED
Old Feb 2, 2007 | 09:48 AM
davlan88's Avatar
davlan88
Well guys, Im am the proud new owner of a 43k 2003 F250 CC Lariat 4WD PSD! So far I have been VERY impressed with this purchase. I drove an hour and a half to get it and no issues on the way home last night or my hour commute to work this morning. So far, so good...knock on wood. The truck seems extremely healthy and FULL of power! I love it! Very smooth driving, more quiet than others I have driven and just overall nice! Thanks to all of those that gave me input and helped me make this decision. Im sure you will be seeing a lot of me now.
I couldnt pull an Oasis on this one due to it being at a GM dealership. I pulled the trigger because the thing was just plain powerful, tight, smooth and the deal was better than I had in mind. If at all possible for the powers that be to pull just this last one Oasis for me, it would be greatly appreciated.
Old Feb 2, 2007 | 09:50 AM
davlan88's Avatar
davlan88
Also, any advice or suggestions for a new to diesel owner are more than welcome!
Old Feb 2, 2007 | 10:03 AM
2006PSDSD's Avatar
2006PSDSD
Drive it like you stole it! Seriously, these turbos are notorious for having vane sticking issues, caused by soot clogging them up. These engines like to be run hard, and you will probably enjoy it as well, its exciting when you can't peel your head off the head rest during WOT. Other than that, keep up with maintenance, and change your oil every 5k or so, with Ford approved oil and filter. I use Motorcraft oil and filters on my '06. Nice buy, have fun with it!
Old Feb 2, 2007 | 10:15 AM
Enomra's Avatar
Enomra
Run your Oasis report on it.... Post the VIN# and one of the wonderful techs on this site will run it for you. It may have the updated turbo on it. My 2003 with 35k miles that I traded in late last year had the new updated turbo on it and so might yours.... Don't worry too much about all of the negative comments you may hear... Ford has all the bugs worked out and these are great motors. Find a good local Ford dealership with a great diesel tech and enjoy......
Old Feb 2, 2007 | 10:48 AM
davlan88's Avatar
davlan88
2003 F250 PSD CC with 43k VIN: 1FTNW21P93EB81618
Old Feb 2, 2007 | 11:24 AM
bigredtruckmi's Avatar
bigredtruckmi
Veteran: Navy
I'vefound on my 04. Run premium fuel and it runs even better. These machines require a very good/clean fuel to run properly. Don't skimp on fuel filters or try to run longer than reccommended. If you notice a slight power loss change both fuel filters.
Old Feb 2, 2007 | 11:58 AM
BowTieHatr's Avatar
BowTieHatr
ok i got ya
thanks for heads up enomra
Old Feb 2, 2007 | 12:09 PM
Enomra's Avatar
Enomra
Anytime you da man!!!!!!!!!!
Old Feb 2, 2007 | 12:10 PM
BowTieHatr's Avatar
BowTieHatr
nah just doin my part to help.
Old Feb 2, 2007 | 12:12 PM
davlan88's Avatar
davlan88
Thanks again Bowtie hatr, I was sweating the outcome, but the darn thing just ran so good and the interior looked and smelled brand new and they made me a deal I couldnt refuse. they beat my number in my head by $2000. I would have bought the same truck for $2000 more and been comfortable, so it was all around good. And to hear it has no major issues is great too. I bought an extended warranty bumper-to-bumper as a safe guard since they beat the price in my head. Now for some new rims and tires!!!! I am quite satisfied with the power at this point, so aesthetics, here we come!
Old Feb 2, 2007 | 12:13 PM
davlan88's Avatar
davlan88
By the way, where can you find "premium" diesel? The places i have seen only carry one diesel pump.
Old Feb 2, 2007 | 12:15 PM
bigredtruckmi
Veteran: Navy
You'll just have to look in your area. Some truck stops have it as do some local fueling sites.
If not then I would look at a diesel fuel additive to raise the cetane by 6 points. This way is a more expensive option and messier. You have to pour in a certain amount per fill.
Old Feb 2, 2007 | 12:28 PM
davlan88's Avatar
davlan88
I guess I am just going to have to look around. i live in a highly populated part of town, so big trucks are not common in my area either are diesel pumps.
Old Feb 2, 2007 | 04:23 PM
03 Power Smoke's Avatar
03 Power Smoke
VIN VEH LINE MKT DERIV BODY CAB VER SERIES DRIVE TYPE PLT CD TRS CD ENG CD PROD DATE WARR DATE SELLING DEALER SELL CNT TIS WCC CPSC_6 PREF BASE SUFF CCC CD DIST(Miles)
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 0 2B01 030701 * 12K073 * D36 42 12
AWS Claim Key: 622772 Trx Code: S07 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:11-FEB-2003 Doc #:110785A
Tech Comments: SELF TEST PCM, RAUGE MALFUNCTION, NO REPAIRS AT THIS TIME SEE SSM# 16488
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 1 7F02 011601 * 17528 * W05 42 200
AWS Claim Key: 1687633 Trx Code: 1 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:03-JUL-2003 Doc #:113885A
Tech Comments: REPLACED WIPER BLADES
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 7 2G05 031405 * RECAL * D36 42 6210
AWS Claim Key: 3911954 Trx Code: 1 Labor Hrs: 1.1
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:29-DEC-2003 Doc #:117712A
Tech Comments: PROGRAMMED PCM TO LATEST UPDATE
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 8 2G04 031401 * 12A650 * D10 42 7705
AWS Claim Key: 4447625 Trx Code: S07 Labor Hrs: 0.9
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:09-FEB-2004 Doc #:01047701
Cust Comments: CK ENG LATEST PROGRAM PER OWNER ENG USED 1 2 TANK OF FUEL TO CORDELE AND BACK
Tech Comments: CC 42 SELF TEST PASS DATA LOGGER ALL NUMBERS IN SPEC CK AND REPROGRAMMED PCM TO LATEST UP DATE D03 CCC 6005F .4 1250D84 .5
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 11 2G01 * * * * * * 9962
AWS Claim Key: 5890342 Trx Code: 03L12 Labor Hrs: 0.2
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:07-MAY-2004 Doc #:01244203
Cust Comments: PERFORM RECALL AS PER INSTRUCTIONS
Tech Comments: RECALL 03L12B .2 COMPLETED
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 16 6L17 011202 2C3Z 25519A70 AAC N30 01 15021
AWS Claim Key: 8009158 Trx Code: E84 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:14-OCT-2004 Doc #:01590803
Cust Comments: CK ROOF CONSOLE DOOR BROKE CK LOCK
Tech Comments: CONSOLE ROOF DOOR BROKE REPLACE CONSLOE
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 22 2E05 100106 3C3Z 9B249 AB G29 42 19645
AWS Claim Key: 10190342 Trx Code: E84 Labor Hrs: 1.6
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:28-MAR-2005 Doc #:01948502
Cust Comments: CUSTOMER STATES WATER IN FUEL LIGHT STAYING ON
Tech Comments: PERFORM DIAGNOSTICS FOUND CONTAMINATED SENSOR IN SEPERATOR REPLACE FUEL WATER SEPERATOR
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 27 2G04 031401 * 12A650 * D36 42 25633
AWS Claim Key: 11911789 Trx Code: S07 Labor Hrs: 1.2
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:06-SEP-2005 Doc #:02285101
Cust Comments: BLOWS BLK SMOKE FUEL MILEAGE DROPPED WHEN IT STARTED SMOKIN
Tech Comments: EEC TEST PCM OUT OF DATE UPDATED AND REPROGRAMMED PCM TO LATEST CALIBRATION
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 34 * * * * * * * 34113
AWS Claim Key: 13369680 Trx Code: 06E17 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:02692602
Cust Comments: PERFORM RECALL AS PER INSTRUCTIONS 06E17 EP SENSOR
Tech Comments: 1 COMPLETED RECALL 06E17 RECAL AS PER RECALL
AWS Claim Key: 13369679 Trx Code: 59B01 Labor Hrs: 0.3
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:21-MAR-2006 Doc #:02692603
Cust Comments: DIAGNOSE RECALL 59B01 TEST DRIVE
Tech Comments: 1 COMPLETED AS PER RECALL
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 35 1F06 030304 6C3Z 8A080 A L87 01 35018
AWS Claim Key: 13651958 Trx Code: E84 Labor Hrs: 0.7
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:24-APR-2006 Doc #:02769701
Cust Comments: CUSTOMER STATES COOLANT LEAKING
Tech Comments: COOLANT RECOVERY JUG CRACKED REPLACED COOLANT RES.
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 35 7N02 011103 YC3Z 1523395 AA G07 42 35035
AWS Claim Key: 13765599 Trx Code: E83 Labor Hrs: 0.8
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:08-MAY-2006 Doc #:02801902
Cust Comments: D S WINDOW KEEPS RUNNING AFTER IT GETS ALL THE WAY UP HUMMING
Tech Comments: MOTOR AND REGULATOR FAULTY REMOVED DOOR PANEL AND REPLACED WINDOW REGULATOR AND MOTOR
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 39 2E06 030008 3C3Z 9E527 AE D41 42 35618
AWS Claim Key: 14396638 Trx Code: S07 Labor Hrs: 4.8
Dlr Cd-Sub Cd: 05002 - * Name: GRIFFIN FORD-LINCOLN-MERCURY, INC. Ph: 229-3821300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:01-SEP-2006 Doc #:03039603
Cust Comments: CUSTOMER STATES ENGINE RUNS ROUGH UNDER LOAD BLOWS BLK SMOKE AND BOGS DOWN
Tech Comments: P0275 P0404 EEC TEST CODES PO275 AND PO404 PRESENT PIN POINT TEST FUEL EGR SYSTEM TEST ICP,INJECTOR TEST REPLACED EGR VALVE AND CYLINDER #5 INJECTOR RETEST
1FTNW21P93EB81618 T/F7 F T/BC T/BD T/E A1 T/BE T/YB 23-JAN-2003 02-JUL-2003 121594 USA 42 * * * * * * * 42002
AWS Claim Key: 14670099 Trx Code: 04S15 Labor Hrs: 0.4
Dlr Cd-Sub Cd: 04988 - * Name: LANGDALE FORD CO Ph: 229-3332300 St:GA Ctry Cd: USA Reg Cd: NA Repr Date:30-NOV-2006 Doc #:22339201
Cust Comments: RECALL OPEN NEGATIVE BATTERY TERMINAL TO ENGINE BLOCK CONNECTION
Tech Comments: PER FORD PERFORMED RECALL O4S15 INSPECTED GROUND STRAP & REPLACED GROUND STARTER.
