: My friends Bronco is stuck in a garage right now and the garage owner can't find what's wrong. ---It was one of those I broke down here so this is where I have to get it fixed situations. ---He says the fuel pump isn't getting any power. ---The only suggestion the garage owner has made is that it might be the computer. It's a 95 Bronco XLT with a 5.0L. ---If it is the computer could someone also point me to a board where I could pick up a good used one. ---Any help would be welcomed. ---Thanks, Mike stuck in Whiting,NJ
my 90/5ltr/efi had a bad fuel pump relay, which caused the fuel pump to not come on. on cab side of air filter box, 3 or 4 plug in relays. also check the kill/roll over switch that is by the emergency break.
I have a 93 and it is actually relay # 2 on mine, followed by a 20 amp Maxi fuse in the box next to it Space #12 to be specific. Also, the Inertia switch is what Ford calls the Kill/Rollover switch and it is definately a good thing to check. All the info is in the manual.
yo diggum
Our 96 Bronco has the following (iaw Owner's Guide and actual installation):
In Power Distribution Box;
Relay #2 - Fuel Pump
Fuse #16 - Fuel Pump Feed 20 amp maxi
Fuse #9 - Fuel Pump Relay Coil (& Powertrain Control System) 20 amp maxi
