towing capacity
Old Feb 1, 2007 | 08:14 PM
kenpobuck's Avatar
kenpobuck
towing capacity
I was wondering if a 92 f150 extended cab 2wheel drive with 300 six and 4 speed overdrive would pull an 83 full size Bronco with a tow bar (about 100 miles) with little or no ill effects? I know better than to use the overdrive, but don't know if the truck can do the job. thanks for any info in advance.
Old Feb 1, 2007 | 08:49 PM
k460's Avatar
k460
You should be fine with that, just stop quicker, drive slower, lock it out of o/d and dont use the bumper to hitch it to if at all possible
Old Feb 1, 2007 | 09:33 PM
BoltBuster's Avatar
BoltBuster
Do you have a Trans cooler other than stock?, I recommend it
F150 capable of towing 5000lb safely. This also depends if your towing it on a continuous flat surface, foothills, mountains, etc....
Old Feb 2, 2007 | 06:30 AM
Leader's Avatar
Leader
Yes the truck is fully capable of pulling the Bronco 100 miles without ANY adverse effects. It can be done safely & legally.
The only question here .... Is the driver up to the challenge.
Old Feb 2, 2007 | 07:59 AM
Acemandb's Avatar
Acemandb
I prefer to think about stopping capability than towing capacity.
Brakes in good shape ?
Old Feb 2, 2007 | 03:48 PM
kenpobuck's Avatar
kenpobuck
The truck has a 4/od stick not automatic and yes the brakes are good. I will be doing the driving and it will be down Indiana 1 to northern kentucky.
