romp romp romp.... help
Old 02-01-2007, 05:29 PM
mudracin74's Avatar
mudracin74
mudracin74 is offline
ive searched and searched the forums and came up w/ a few suggestions on a fix for the romp romp on cold start up. tried waiting for the fuel pump to stop running, tried cycleing the glow plugs a few extra times, checked the glow plug relay. it seems to do it once it gets colder than 30 degrees w/o being plugged in. dosnt do it when plugged in. its a problem because i cannot plug it in at work, or when im ice fishing, or when the girlfriend parks it at her dorm. could running thicker 15w-40 oil be causing this? or are not all the glow plugs working? any help would be great. many thanks
Old 02-01-2007, 05:33 PM
empiretc's Avatar
empiretc
empiretc is offline
in the colder weather you should run 5-40. I run 15-40 year round just because it never gets that cold for very long where I live. If you can, plug the truck in when it is that cold.
Old 02-01-2007, 05:37 PM
ron's power stroke's Avatar
ron's power stroke
ron's power stroke is offline
[QUOTE=mudracin74]ive searched and searched the forums and came up w/ a few suggestions on a fix for the romp romp on cold start up. tried waiting for the fuel pump to stop running, tried cycleing the glow plugs a few extra times, checked the glow plug relay. it seems to do it once it gets colder than 30 degrees w/o being plugged in. dosnt do it when plugged in. its a problem because i cannot plug it in at work, or when im ice fishing, or when the girlfriend parks it at her dorm. could running thicker 15w-40 oil be causing this? or are not all the glow plugs working? any help would be great. many thanks[/QUOT
i run 15/40 delo 400 and dont plug my truck in till below 0.. i turn on the key for the glow plugs wait for a minute or 2 then start the truck..at 0 i barly get a romp from my truck. but i do get blue smoke for a minute or so..
Old 02-01-2007, 05:40 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
I agree with empiretc, a truck that is prone to the romps, a lighter weight diesel oil and/or synthetic will help eliminate or reduce hard cold starts. It is also essential that you have a good working GP system though.....
Old 02-01-2007, 05:42 PM
mudracin74's Avatar
mudracin74
what are the pin assignments so i can check the glow plugs. if i remember they should be 12 ohms right?
Old 02-01-2007, 05:48 PM
guzzle92's Avatar
guzzle92
guzzle92 is offline
Here is a short thread on how to test the GP's.
https://www.ford-trucks.com/forums/5...est+glow+plugs
Old 02-01-2007, 05:55 PM
mudracin74's Avatar
mudracin74
thanks ill check the glow plugs, but i dont really want to switch to 5w-40 right now i only have 700 miles on the 15w-40 thats in it.
Old 02-01-2007, 06:12 PM
mybigredford's Avatar
mybigredford
mybigredford is offline
i run delo 5-40 synthetic all year round, my truck starts in -20 no problem, starts like it is 80*, i love the syn oil!!
Old 02-01-2007, 06:14 PM
mudracin74's Avatar
mudracin74
it starts no prob in -20 degree weather w/o being plugged in???
nossliw
29
02-23-2015 12:56 PM
honeydew
23
08-19-2013 11:12 AM
kawirider00
27
11-10-2012 08:53 AM
90pioneer
10-18-2011 11:16 PM
esmarkey
02-07-2010 06:58 PM
Quick Reply: romp romp romp.... help
