1978 - 1996 Big Bronco
Please Help, Wierd Noise!!!
Old Aug 20, 2002 | 09:10 PM
holl's Avatar
holl
[updated:LAST EDITED ON 20-Aug-02 AT 10:12 PM (EST)]Okay, let me try to describe this. At slow speeds I can hear a clunking noise that seems to increase with wheel speed. Also, when I hit a bump at lower speeds I can hear a rattling noise. Both noises seem to be coming out of the front end, and both disappear when I push on the brake peddle. Please help, this is driving me nuts.
Old Aug 20, 2002 | 09:22 PM
88BroncoXLT's Avatar
88BroncoXLT
give some info on the truck(year - mph range for the sound). but sounds like the wheel bearings are not tight.
good luck
chris
Old Aug 20, 2002 | 09:53 PM
holl's Avatar
holl
It's a 1979 Bronco Ranger XLT. It has 88 thousand miles on it. I am not sure if the noise goes away at certain speeds it is just easier to hear at lower speeds. Also I just replaced the brake pads and I do not remeber if the noise was there before or not. I don't think it was though. Could it be faulty calipers? I really had to lay into the caliper spreader to get the pistons back far enough to get the new pads on the rotors.
Old Aug 20, 2002 | 10:53 PM
Alrobot's Avatar
Alrobot
check your lug nuts. also check the caliper slides.
Old Aug 21, 2002 | 06:50 AM
holl's Avatar
holl
The lug nuts are tight and the calipers are solid!!
Old Jan 4, 2003 | 02:28 PM
79_250RangerLariat's Avatar
79_250RangerLariat
Old Jan 4, 2003 | 11:49 PM
robmamayek's Avatar
robmamayek
I had a u joint go out in the back and it sounded like it came from the front(transmision shaken it up)
Keny1
Dec 25, 2021 05:13 PM
johntorg
Apr 3, 2017 11:51 AM
09f250v10
6.7L Power Stroke Diesel
Aug 22, 2016 06:51 PM
racin
1997 - 2003 F150
Jan 14, 2016 10:17 PM
BigBlkEX
Jan 10, 2014 09:41 PM
